Hi, first post here, and first major problem with my node. It appears that after upgrading to Umbrel OS 1.0 a little over two months ago, it went through successfully, but it did not remove the old state, after the migration was completed.
Now my 2TB drive is completely full. I just need some help with the correct command to delete the old state. I’m desperate to get my node fixed, and back running. Any instructions would be most welcome. I am not the most comfortable operating on the command line.
Here is what I got when prompted by Umbrel support, but have not heard back from them, so am hoping someone else can jump in and help me. Thanks very much!!
umbrel@umbrel:~$ du -h -a / 2>/dev/null | sort -h -r | head -n 100
2.3T /
757G /mnt/data
757G /mnt
755G /data/umbrel-os
755G /data
753G /mnt/data/umbrel/app-data
753G /home/umbrel/umbrel/app-data
753G /home/umbrel
753G /home
753G /data/umbrel-os/home/umbrel/umbrel/app-data
701G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin
701G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin
701G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin
628G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/blocks
628G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/blocks
628G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/blocks
61G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/indexes
61G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes
61G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes
51G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/indexes/txindex
51G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes/txindex
51G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes/txindex
47G /mnt/data/umbrel/app-data/electrs/data/electrs/db/bitcoin
47G /home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin
47G /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin
12G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/chainstate
12G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/chainstate
12G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/chainstate
11G /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/indexes/blockfilter/basic
11G /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes/blockfilter/basic
11G /data/umbrel-os/home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/indexes/blockfilter/basic
6.6G /run/rugpi
6.6G /run
5.1G /mnt/data/umbrel/app-data/mempool
5.1G /home/umbrel/umbrel/app-data/mempool
5.1G /data/umbrel-os/home/umbrel/umbrel/app-data/mempool
4.7G /run/rugpi/mounts
4.7G /mnt/data/umbrel/app-data/mempool/mysql/data
4.7G /home/umbrel/umbrel/app-data/mempool/mysql/data
4.7G /data/umbrel-os/home/umbrel/umbrel/app-data/mempool/mysql/data
4.5G /mnt/data/umbrel/app-data/mempool/mysql/data/mempool
4.5G /home/umbrel/umbrel/app-data/mempool/mysql/data/mempool
4.5G /data/umbrel-os/home/umbrel/umbrel/app-data/mempool/mysql/data/mempool
4.1G /swap/swapfile
4.1G /swap
4.1G /mnt/data/swap/swapfile
4.1G /mnt/data/swap
3.8G /mnt/data/umbrel/app-data/mempool/mysql/data/mempool/node_stats.ibd
3.8G /home/umbrel/umbrel/app-data/mempool/mysql/data/mempool/node_stats.ibd
3.8G /data/umbrel-os/home/umbrel/umbrel/app-data/mempool/mysql/data/mempool/node_stats.ibd
2.8G /run/rugpi/mounts/system
2.1G /usr
2.1G /run/rugpi/mounts/system/usr
2.0G /var
1.9G /var/log/journal/0a8f00f31f164f27992e0ec945a887d2
1.9G /var/log
1.9G /run/rugpi/state/persist/data/umbrel-os/var/log/journal/0a8f00f31f164f27992e0ec945a887d2
1.9G /run/rugpi/mounts/data/state/default/persist/data/umbrel-os/var/log/journal/0a8f00f31f164f27992e0ec945a887d2
umbrel@umbrel:~$ du -h -a /data 2>/dev/null | sort -h -r | head -n 100
755G /data
1.9G /data/umbrel-os/var/log/journal/0a8f00f31f164f27992e0ec945a887d2
535M /data/umbrel-os/home/umbrel/umbrel/app-data/lightning/data/lnd
528M /data/umbrel-os/home/umbrel/umbrel/app-data/lightning/data/lnd/data
385M /data/umbrel-os/home/umbrel/umbrel/app-data/mempool/data
385M /data/umbrel-os/home/umbrel/umbrel/app-data/lightning/data/lnd/data/graph/mainnet
377M /data/umbrel-os/home/umbrel/umbrel/app-data/lightning/data/lnd/data/graph/mainnet/channel.db
311M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/LOG.old.1723603254016305
269M /data/umbrel-os/home/umbrel/umbrel/app-data/mempool/mysql/data/mempool/statistics.ibd
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083455.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083454.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083453.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083452.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083451.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083450.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083449.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083448.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083447.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083446.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083445.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083444.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083438.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083437.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083436.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083435.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083434.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083433.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083432.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083430.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083429.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083428.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083427.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083426.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083425.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083424.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083418.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083412.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083411.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083410.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083409.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083408.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083407.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083406.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083405.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083404.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083403.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083402.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083401.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083400.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083399.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083398.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083386.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083385.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083384.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083383.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083377.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083376.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083375.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083374.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083373.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083367.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083366.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083365.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083364.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083363.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083357.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083356.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083355.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083354.sst
259M /data/umbrel-os/home/umbrel/umbrel/app-data/electrs/data/electrs/db/bitcoin/1083353.sst
