After I updated to Umbrel 1.1, when I login, I do not get a 2FA authentication prompt, and all apps are gone. If I unplug my 2 TB USB SSD that I use with Time Machine/Back That Mac Up, I receive a 2FA authentication prompt, and all my apps & data are there. It doesn’t matter if the 2 TB SSD is plugged into USB 2 or USB 3 ports. The only current solution is to boot the device with the SSD unplugged.
Appreciate any advice.
Rich
