When I try to start llama-gpt api using docker-compose-gguf.yml, I get a bunch o…f errors (see below) on the api containers.
I've also tried with different .gguf models, but still seeing the same errors.
Any idea what is causing the errors?
Thanks
lama-gpt-api_llama-gpt-api_1 exited with code 1
llama-gpt-ui_1 | [INFO wait] Host [llama-gpt-api:8000] not yet available...
llama-gpt-api_1 | /usr/local/lib/python3.11/site-packages/setuptools/command/develop.py:40: EasyInstallDeprecationWarning: easy_install command is deprecated.
llama-gpt-api_1 | !!
llama-gpt-api_1 |
llama-gpt-api_1 | ********************************************************************************
llama-gpt-api_1 | Please avoid running ``setup.py`` and ``easy_install``.
llama-gpt-api_1 | Instead, use pypa/build, pypa/installer or other
llama-gpt-api_1 | standards-based tools.
llama-gpt-api_1 |
llama-gpt-api_1 | See https://github.com/pypa/setuptools/issues/917 for details.
llama-gpt-api_1 |
llama-gpt-api_1 | easy_install.initialize_options(self)
llama-gpt-api_1 | [1/2] Generating /app/vendor/llama.cpp/libllama.so
llama-gpt-api_1 | FAILED: /app/vendor/llama.cpp/libllama.so
llama-gpt-api_1 | cd /app/vendor/llama.cpp && make libllama.so
llama-gpt-api_1 | make[1]: Entering directory '/app/vendor/llama.cpp'
llama-gpt-api_1 | I llama.cpp build info:
llama-gpt-api_1 | I UNAME_S: Linux
llama-gpt-api_1 | I UNAME_P: unknown
llama-gpt-api_1 | I UNAME_M: x86_64
llama-gpt-api_1 | I CFLAGS: -I. -O3 -std=c11 -fPIC -DNDEBUG -Wall -Wextra -Wpedantic -Wcast-qual -Wdouble-promotion -Wshadow -Wstrict-prototypes -Wpointer-arith -Wmissing-prototypes -pthread -march=native -mtune=native -DGGML_USE_K_QUANTS
llama-gpt-api_1 | I CXXFLAGS: -I. -I./common -O3 -std=c++11 -fPIC -DNDEBUG -Wall -Wextra -Wpedantic -Wcast-qual -Wno-unused-function -Wno-multichar -pthread -march=native -mtune=native -DGGML_USE_K_QUANTS
llama-gpt-api_1 | I LDFLAGS:
llama-gpt-api_1 | I CC: cc (Debian 10.2.1-6) 10.2.1 20210110
llama-gpt-api_1 | I CXX: g++ (Debian 10.2.1-6) 10.2.1 20210110
llama-gpt-api_1 |
llama-gpt-api_1 | cc -I. -O3 -std=c11 -fPIC -DNDEBUG -Wall -Wextra -Wpedantic -Wcast-qual -Wdouble-promotion -Wshadow -Wstrict-prototypes -Wpointer-arith -Wmissing-prototypes -pthread -march=native -mtune=native -DGGML_USE_K_QUANTS -c ggml.c -o ggml.o
llama-gpt-api_1 | In file included from /usr/lib/gcc/x86_64-linux-gnu/10/include/immintrin.h:111,
llama-gpt-api_1 | from ggml.c:302:
llama-gpt-api_1 | ggml.c: In function ‘ggml_vec_dot_q4_0_q8_0’:
llama-gpt-api_1 | /usr/lib/gcc/x86_64-linux-gnu/10/include/fmaintrin.h:63:1: error: inlining failed in call to ‘always_inline’ ‘_mm256_fmadd_ps’: target specific option mismatch
llama-gpt-api_1 | 63 | _mm256_fmadd_ps (__m256 __A, __m256 __B, __m256 __C)
llama-gpt-api_1 | | ^~~~~~~~~~~~~~~
llama-gpt-api_1 | ggml.c:2527:15: note: called from here
llama-gpt-api_1 | 2527 | acc = _mm256_fmadd_ps( d, q, acc );
llama-gpt-api_1 | | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~
llama-gpt-api_1 | make[1]: *** [Makefile:349: ggml.o] Error 1
llama-gpt-api_1 | make[1]: Leaving directory '/app/vendor/llama.cpp'
llama-gpt-api_1 | ninja: build stopped: subcommand failed.
llama-gpt-api_1 | Traceback (most recent call last):
llama-gpt-api_1 | File "/usr/local/lib/python3.11/site-packages/skbuild/setuptools_wrap.py", line 674, in setup
llama-gpt-api_1 | cmkr.make(make_args, install_target=cmake_install_target, env=env)
llama-gpt-api_1 | File "/usr/local/lib/python3.11/site-packages/skbuild/cmaker.py", line 697, in make
llama-gpt-api_1 | self.make_impl(clargs=clargs, config=config, source_dir=source_dir, install_target=install_target, env=env)
llama-gpt-api_1 | File "/usr/local/lib/python3.11/site-packages/skbuild/cmaker.py", line 742, in make_impl
llama-gpt-api_1 | raise SKBuildError(msg)
llama-gpt-api_1 |
llama-gpt-api_1 | An error occurred while building with CMake.
llama-gpt-api_1 | Command:
llama-gpt-api_1 | /usr/local/lib/python3.11/site-packages/cmake/data/bin/cmake --build . --target install --config Release --
llama-gpt-api_1 | Install target:
llama-gpt-api_1 | install
llama-gpt-api_1 | Source directory:
llama-gpt-api_1 | /app
llama-gpt-api_1 | Working directory:
llama-gpt-api_1 | /app/_skbuild/linux-x86_64-3.11/cmake-build
llama-gpt-api_1 | Please check the install target is valid and see CMake's output for more information.
llama-gpt-api_1 |
llama-gpt-api_1 | make: *** [Makefile:9: build] Error 1
llama-gpt-api_1 | Initializing server with:
llama-gpt-api_1 | Batch size: 2096
llama-gpt-api_1 | Number of CPU threads: 4
llama-gpt-api_1 | Number of GPU layers: 0
llama-gpt-api_1 | Context window: 4096
llama-gpt-api_1 | File "<frozen runpy>", line 189, in _run_module_as_main
llama-gpt-api_1 | File "<frozen runpy>", line 112, in _get_module_details
llama-gpt-api_1 | File "/app/llama_cpp/__init__.py", line 1, in <module>
llama-gpt-api_1 | from .llama_cpp import *
llama-gpt-api_1 | File "/app/llama_cpp/llama_cpp.py", line 80, in <module>
llama-gpt-api_1 | _lib = _load_shared_library(_lib_base_name)
llama-gpt-api_1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
llama-gpt-api_1 | File "/app/llama_cpp/llama_cpp.py", line 71, in _load_shared_library
llama-gpt-api_1 | raise FileNotFoundError(
llama-gpt-api_1 | FileNotFoundError: Shared library with base name 'llama' not found
llama-gpt-api_llama-gpt-api_1 exited with code 1
docker-compose.yaml:
version: '3.6'
services:
llama-gpt-api:
# Pin to llama-cpp-python 0.1.80 with GGUF support
image: ghcr.io/abetlen/llama-cpp-python:latest@sha256:de0fd227f348b5e43d4b5b7300f1344e712c14132914d1332182e9ecfde502b2
restart: on-failure
volumes:
- './models:/models'
- './api:/api'
ports:
- 3001:8000
environment:
MODEL: '/models/${MODEL_NAME:-code-llama-2-7b-chat.gguf}'
MODEL_DOWNLOAD_URL: '${MODEL_DOWNLOAD_URL:-https://huggingface.co/TheBloke/CodeLlama-7B-Instruct-GGUF/resolve/main/codellama-7b-instruct.Q4_K_M.gguf}'
N_GQA: '${N_GQA:-1}'
USE_MLOCK: 1
cap_add:
- IPC_LOCK
command: '/bin/sh /api/run.sh'
llama-gpt-ui:
# TODO: Use this image instead of building from source after the next release
# image: 'ghcr.io/getumbrel/llama-gpt-ui:latest'
build:
context: ./ui
dockerfile: Dockerfile
ports:
- 3002:3000
restart: on-failure
environment:
- 'OPENAI_API_KEY=sk-XXXXXXXXXXXXXXXXXXXX'
- 'OPENAI_API_HOST=http://llama-gpt-api:8000'
- 'DEFAULT_MODEL=/models/${MODEL_NAME:-llama-2-7b-chat.bin}'
- 'NEXT_PUBLIC_DEFAULT_SYSTEM_PROMPT=${DEFAULT_SYSTEM_PROMPT:-"You are a helpful and friendly AI assistant. Respond very concisely."}'
- 'WAIT_HOSTS=llama-gpt-api:8000'
- 'WAIT_TIMEOUT=${WAIT_TIMEOUT:-3600}'
