Lightning app using all ram
having an issue with my node , need help
im running umrbel on a pi 4 at present
the lightning app is maxing out my ram, to the point it is becoming unresposive, cant even run commands in terminal, it just takes ages to load. It has restrted by itself as well. if i manage to get it restarted the lightning ram usage will drop to just over a gig but slowly build up to over 6 GIG and evrything just grinds to a halt.
At present it hs now gone offline totally and cant log in at all or see it in my browser , I guess i have to pull power now???
I have also done a compaction (Compact the LND database (channel.db) but that didnt help, the channel db is saying its about 800Meg
Any ideas??
Could you share a debug log and confirm what platforms we’re working with, a Raspberry Pi 4?
For reference check out FAQ under “Generating Troubleshooting Logs” here: Official Umbrel Troubleshooting Guide and FAQ - Guides - Umbrel Community
System > Troubleshoot > Start and it will generate it from you right there within the dashboard and download it, then you can attach it here, one easy way to share for easy review is to paste it to www.pastebin.com and share a link
(you can also consult the guide above on Generating the log, there will also be steps to generate it within a terminal window via SSH if there is any issue that prevents you from generating within the UI)
And we can take a look to get you up and running ASAP!
Hi Mate
I did post on telegram but seems so manny scammers i dont now who is real and who isnt
My node restarted by itself again and started out at 1.3 gig ram for lightning but is back to over but is back to 6.4 G. it is now unusable again , I had terminal open on HTOP and I cant even close this. The whole thing has ground to a halt again. I am very concerned about my funds at present. I did mangae to get a log dowloaded before it froze. I havent used paste bin before so hope this is correct
I am using a pi 4 8G, Its in an argon case with m.2 2TB sata ssd
ok since i replied the ligtning app has restarted itself. its currently restarting which takes about 40 minutes. so the sequence seems to be it starts up and works for a little while , the ram usage steadily climbs until it just bogs down and becomes unusable, then it restrts the lightning app by itself.
Earlier this morning when it was running i powered off node using ui then when it said it was safe unplugged node from power and network. replugged it in and it restarted but still has the same issue
I am using an official pi power source as well
When it restarts the lightning app the bitcoin app is still accessible and syncing. so it appears its just restarting the lightning app
another thing that is happening is when the lightning app restarts I am unable to log back into thunderhub and lightning terminal, i have to uninstall apps and reinstall
