I have trying to open a channel, he stucked on opening, not on mempool for week now. I want to close it but no option how. Any help on this issue. Thanks.
Hi, just to clarify, your channel is still pending because the fee-rate is too low?
You will need to bump it up with RBF or a CPFP transaction. Unconfirmed Bitcoin Transactions
You can use ‘Ride The Lightning’ to do this pretty easily, or via command-line if are confident enough
Can’t bump it it hasn’t entered mempool. When restarted node i get funds back but that opening channel still there.
