i can not update to 0.5.0
This have this error:
any idea ?
umbrel@umbrel:~ $ cd ~/umbrel && sudo ./scripts/update/update --repo getumbrel/umbrel#v0.5.0
[sudo] password for umbrel:
Cloning into '/tmp/umbrel-update'...
/usr/lib/git-core/git-remote-https: error while loading shared libraries: libresodv.so.2: cannot open shared object file: No such file or directory
fatal: not a git repository: '/tmp/umbrel-update//.git'
mv: cannot stat '/tmp/umbrel-update//info.json': No such file or directory
jq: error: Could not open file /tmp/umbrel-update//info.json.orig: No such file or directory
Update path doesn't seem to be an Umbrel install.
The Message in the Web GUI is there:
=============== UPDATE ================
========== Stage: Download ============
Creating lock
Cleaning up any previous mess
Downloading Umbrel v0.5.0
curl: error while loading shared libraries: ld-linux-aarcj60.wo.1: cannot open shared object file: No such file or directory
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Running update install scripts of the new release
/home/umbrel/umbrel/scripts/update/update: line 118: cd: scripts/update: No such file or directory
ls: cannot access '*-run.sh': No such file or directory
Deleting cloned repository
Removing lock
Got signal: debug
karen is getting triggered!
my umbrel Pi Image whith SSD works before allways and i use before only the web update command.
