Hello! I am unable to access my umbrel by going to umbrel.local in my browser.
I was able to login to it using SSH. Upon checking the umbrel/statuses/update-status.json file the status was failed.
So I decided to do manual update in my SSH using update script.
I ran the following command:
sudo ~/umbrel/scripts/update/update --repo getumbrel/umbrel#1.3.0
And got the following log:
=============== UPDATE ================
========== Stage: Download ============
Creating lock
Cleaning up any previous mess
Copying Umbrel 1.0.0 from /tmp/umbrel-update/
Running update install scripts of the new release
== Begin Update Script 00-run.sh ==
========= Stage: Pre-update ===========
Installing Umbrel 1.0.0 at /home/umbrel/umbrel
Fixing permissions
Backing up existing directory tree
rsync: [client] failed to open include file /home/umbrel/umbrel/.umbrel-1.0.0/scripts/update/.updateinclude: No such file or directory (2)
rsync error: error in file IO (code 11) at exclude.c(1481) [client=3.2.7]
== End Update Script 00-run.sh ==
How can I resolve this issue please? Thanks!
