2025-06-27T15:17:18Z Included configuration file umbrel-bitcoin.conf
2025-06-27T15:17:18Z Bitcoin Core version v29.0.0 (release build)
2025-06-27T15:17:18Z Using the ‘sse4(1way),sse41(4way)’ SHA256 implementation
2025-06-27T15:17:18Z Default data directory /home/node/.bitcoin
2025-06-27T15:17:18Z Using data directory /data/bitcoin
2025-06-27T15:17:18Z Config file: /data/bitcoin/bitcoin.conf
2025-06-27T15:17:18Z Config file arg: bantime=“86400”
2025-06-27T15:17:18Z Config file arg: blockfilterindex=“1”
2025-06-27T15:17:18Z Config file arg: chain=“main”
2025-06-27T15:17:18Z Config file arg: datacarrier=“1”
2025-06-27T15:17:18Z Config file arg: datacarriersize=“83”
2025-06-27T15:17:18Z Config file arg: dbcache=“450”
2025-06-27T15:17:18Z Config file arg: i2pacceptincoming=“1”
2025-06-27T15:17:18Z Config file arg: i2psam=“10.21.22.11:7656”
2025-06-27T15:17:18Z Config file arg: includeconf=“umbrel-bitcoin.conf”
2025-06-27T15:17:18Z Config file arg: listen=“1”
2025-06-27T15:17:18Z Config file arg: listenonion=“1”
2025-06-27T15:17:18Z Config file arg: maxconnections=“125”
2025-06-27T15:17:18Z Config file arg: maxmempool=“300”
2025-06-27T15:17:18Z Config file arg: maxorphantx=“100”
2025-06-27T15:17:18Z Config file arg: maxreceivebuffer=“5000”
2025-06-27T15:17:18Z Config file arg: maxsendbuffer=“5000”
2025-06-27T15:17:18Z Config file arg: maxuploadtarget=“0”
2025-06-27T15:17:18Z Config file arg: mempoolexpiry=“336”
2025-06-27T15:17:18Z Config file arg: onion=“10.21.22.10:9050”
2025-06-27T15:17:18Z Config file arg: onlynet=“ipv4”
2025-06-27T15:17:18Z Config file arg: onlynet=“ipv6”
2025-06-27T15:17:18Z Config file arg: onlynet=“i2p”
2025-06-27T15:17:18Z Config file arg: peerblockfilters=“1”
2025-06-27T15:17:18Z Config file arg: peerbloomfilters=“0”
2025-06-27T15:17:18Z Config file arg: peertimeout=“60”
2025-06-27T15:17:18Z Config file arg: permitbaremultisig=“0”
2025-06-27T15:17:18Z Config file arg: persistmempool=“1”
2025-06-27T15:17:18Z Config file arg: prune=“0”
2025-06-27T15:17:18Z Config file arg: rest=“1”
2025-06-27T15:17:18Z Config file arg: rpcallowip=“10.21.0.0/16”
2025-06-27T15:17:18Z Config file arg: rpcallowip=“127.0.0.1”
2025-06-27T15:17:18Z Config file arg: rpcauth=****
2025-06-27T15:17:18Z Config file arg: rpcworkqueue=“128”
2025-06-27T15:17:18Z Config file arg: timeout=“5000”
2025-06-27T15:17:18Z Config file arg: torcontrol=“10.21.22.10:9051”
2025-06-27T15:17:19Z Config file arg: torpassword=****
2025-06-27T15:17:19Z Config file arg: txindex=“1”
2025-06-27T15:17:19Z Config file arg: whitelist=“10.21.0.0/16”
2025-06-27T15:17:19Z Config file arg: whitelist=“127.0.0.1”
2025-06-27T15:17:19Z Config file arg: zmqpubhashblock=“tcp://0.0.0.0:28334”
2025-06-27T15:17:19Z Config file arg: zmqpubhashtx=“tcp://0.0.0.0:28336”
2025-06-27T15:17:19Z Config file arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
2025-06-27T15:17:19Z Config file arg: zmqpubrawtx=“tcp://0.0.0.0:28333”
2025-06-27T15:17:19Z Config file arg: zmqpubsequence=“tcp://0.0.0.0:28335”
2025-06-27T15:17:19Z Config file arg: [main] bind=“0.0.0.0:8333”
2025-06-27T15:17:19Z Config file arg: [main] bind=“10.21.21.8:8334=onion”
2025-06-27T15:17:19Z Config file arg: [main] port=“8333”
2025-06-27T15:17:19Z Config file arg: [main] rpcbind=“10.21.21.8”
2025-06-27T15:17:19Z Config file arg: [main] rpcbind=“127.0.0.1”
2025-06-27T15:17:19Z Config file arg: [main] rpcport=“8332”
2025-06-27T15:17:19Z Command-line arg: datadir=“/data/bitcoin”
2025-06-27T15:17:19Z Command-line arg: deprecatedrpc=“create_bdb”
2025-06-27T15:17:19Z Using at most 125 automatic connections (1048576 file descriptors available)
2025-06-27T15:17:19Z scheduler thread start
2025-06-27T15:17:19Z Binding RPC on address 10.21.21.8 port 8332
2025-06-27T15:17:19Z Binding RPC on address 127.0.0.1 port 8332
2025-06-27T15:17:19Z Generated RPC authentication cookie /data/bitcoin/.cookie
2025-06-27T15:17:19Z Permissions used for cookie: rw-------
2025-06-27T15:17:19Z Using random cookie authentication.
2025-06-27T15:17:19Z Using rpcauth authentication.
2025-06-27T15:17:19Z Starting HTTP server with 16 worker threads
2025-06-27T15:17:19Z Using wallet directory /data/bitcoin
2025-06-27T15:17:19Z init message: Verifying wallet(s)…
2025-06-27T15:17:19Z Using /16 prefix for IP bucketing
2025-06-27T15:17:19Z init message: Loading P2P addresses…
2025-06-27T15:17:19Z Loaded 91 addresses from peers.dat 2ms
2025-06-27T15:17:19Z init message: Loading banlist…
2025-06-27T15:17:19Z SetNetworkActive: true
2025-06-27T15:17:19Z Cache configuration:
2025-06-27T15:17:19Z * Using 2.0 MiB for block index database
2025-06-27T15:17:19Z * Using 56.2 MiB for transaction index database
2025-06-27T15:17:19Z * Using 49.2 MiB for basic block filter index database
2025-06-27T15:17:19Z * Using 8.0 MiB for chain state database
2025-06-27T15:17:19Z * Using 334.5 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2025-06-27T15:17:19Z Script verification uses 1 additional threads
2025-06-27T15:17:19Z Using obfuscation key for blocksdir *.dat files (/data/bitcoin/blocks): ‘ec55c3d339bf21fd’
2025-06-27T15:17:19Z Opening LevelDB in /data/bitcoin/blocks/index
2025-06-27T15:17:19Z Opened LevelDB successfully
2025-06-27T15:17:19Z Using obfuscation key for /data/bitcoin/blocks/index: 0000000000000000
2025-06-27T15:17:19Z Using 16 MiB out of 16 MiB requested for signature cache, able to store 524288 elements
2025-06-27T15:17:19Z Using 16 MiB out of 16 MiB requested for script execution cache, able to store 524288 elements
2025-06-27T15:17:19Z init message: Loading block index…
2025-06-27T15:17:19Z Assuming ancestors of block 00000000000000000001b658dd1120e82e66d2790811f89ede9742ada3ed6d77 have valid signatures.
2025-06-27T15:17:19Z Setting nMinimumChainWork=0000000000000000000000000000000000000000b1f3b93b65b16d035a82be84
2025-06-27T15:17:43Z LoadBlockIndexDB: last block file = 4995
2025-06-27T15:17:43Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=76, size=99248862, heights=902140…902239, time=2025-06-21…2025-06-21)
2025-06-27T15:17:43Z Checking all blk files are present…
2025-06-27T15:17:50Z Initializing chainstate Chainstate [ibd] @ height -1 (null)
2025-06-27T15:17:50Z Opening LevelDB in /data/bitcoin/chainstate
2025-06-27T15:17:50Z Opened LevelDB successfully
2025-06-27T15:17:50Z Using obfuscation key for /data/bitcoin/chainstate: 274b3402c1e59538
2025-06-27T15:17:51Z Loaded best chain: hashBestChain=0000000000000000000086985fc0baa7d6c0abbd218efba2b9606dcae82b6d21 height=902239 date=2025-06-21T22:10:54Z progress=0.998110
2025-06-27T15:17:51Z init message: Verifying blocks…
2025-06-27T15:17:51Z Verifying last 6 blocks at level 3
2025-06-27T15:17:51Z Verification progress: 0%
2025-06-27T15:17:52Z Verification progress: 16%
2025-06-27T15:17:52Z Verification progress: 33%
2025-06-27T15:17:53Z Verification progress: 50%
2025-06-27T15:17:53Z Verification progress: 66%
2025-06-27T15:17:54Z Verification progress: 83%
2025-06-27T15:17:54Z Verification progress: 99%
2025-06-27T15:17:54Z Verification: No coin database inconsistencies in last 6 blocks (21853 transactions)
2025-06-27T15:17:54Z Block index and chainstate loaded
2025-06-27T15:17:54Z Opening LevelDB in /data/bitcoin/indexes/txindex
2025-06-27T15:17:54Z Opened LevelDB successfully
2025-06-27T15:17:54Z Using obfuscation key for /data/bitcoin/indexes/txindex: 0000000000000000
2025-06-27T15:17:54Z Opening LevelDB in /data/bitcoin/indexes/blockfilter/basic/db
2025-06-27T15:17:54Z Using obfuscation key for /data/bitcoin/indexes/blockfilter/basic/db: 0000000000000000
2025-06-27T15:17:54Z Setting NODE_NETWORK on non-prune mode
2025-06-27T15:17:54Z block tree size = 902241
2025-06-27T15:17:54Z nBestHeight = 902239
2025-06-27T15:17:54Z initload thread start
2025-06-27T15:17:54Z torcontrol thread start
2025-06-27T15:17:54Z Bound to 0.0.0.0:8333
2025-06-27T15:17:54Z Bound to 10.21.21.8:8334
2025-06-27T15:17:54Z Loaded 0 addresses from “anchors.dat”
2025-06-27T15:17:54Z 0 block-relay-only anchors will be tried for connections.
2025-06-27T15:17:54Z init message: Starting network threads…
2025-06-27T15:17:54Z net thread start
2025-06-27T15:17:54Z dnsseed thread start
2025-06-27T15:17:54Z Waiting 11 seconds before querying DNS seeds.
2025-06-27T15:17:54Z addcon thread start
2025-06-27T15:17:54Z init message: Done loading
2025-06-27T15:17:54Z Got tor service ID cjkp7jjwwbigtktqy3p6le2ouuflok5dhwjtxow4f7sdwsa5grvrpmyd, advertising service cjkp7jjwwbigtktqy3p6le2ouuflok5dhwjtxow4f7sdwsa5grvrpmyd.onion:8333
2025-06-27T15:17:54Z i2paccept thread start
2025-06-27T15:17:54Z msghand thread start
2025-06-27T15:17:54Z opencon thread start
2025-06-27T15:17:54Z txindex thread start
2025-06-27T15:17:54Z Loading 0 mempool transactions from file…
2025-06-27T15:17:54Z Imported mempool transactions from file: 0 succeeded, 0 failed, 0 expired, 0 already there, 0 waiting for initial broadcast
2025-06-27T15:17:54Z initload thread exit
2025-06-27T15:17:54Z basic block filter index thread start
2025-06-27T15:17:54Z [error] ReadBlock: Deserialize or I/O error - ReadCompactSize(): size too large: iostream error at FlatFilePos(nFile=7, nPos=3828080)
2025-06-27T15:17:54Z [error] A fatal internal error occurred, see debug.log for details: Sync: Failed to read block 00000000000004d0c1c3f3a35807792019bc4a414801843055db5ede1d637405 from disk
2025-06-27T15:17:54Z basic block filter index thread exit
Error: A fatal internal error occurred, see debug.log for details: Sync: Failed to read block 00000000000004d0c1c3f3a35807792019bc4a414801843055db5ede1d637405 from disk
2025-06-27T15:17:54Z tor: Thread interrupt
2025-06-27T15:17:54Z Shutdown: In progress…
2025-06-27T15:17:54Z dnsseed thread exit
2025-06-27T15:17:54Z RemoveLocal(cjkp7jjwwbigtktqy3p6le2ouuflok5dhwjtxow4f7sdwsa5grvrpmyd.onion:8333)
2025-06-27T15:17:54Z torcontrol thread exit
2025-06-27T15:17:54Z addcon thread exit
2025-06-27T15:17:54Z opencon thread exit
2025-06-27T15:17:54Z txindex thread exit
2025-06-27T15:17:54Z msghand thread exit
2025-06-27T15:17:54Z net thread exit
2025-06-27T15:17:55Z [i2p:error] Couldn’t listen: Receive interrupted (received 0 bytes without terminator before that)
2025-06-27T15:17:55Z i2paccept thread exit
2025-06-27T15:17:55Z DumpAnchors: Flush 0 outbound block-relay-only peer addresses to anchors.dat started
2025-06-27T15:17:55Z DumpAnchors: Flush 0 outbound block-relay-only peer addresses to anchors.dat completed (0.01s)
2025-06-27T15:17:55Z scheduler thread exit
2025-06-27T15:17:55Z Writing 0 mempool transactions to file…
2025-06-27T15:17:55Z Writing 0 unbroadcast transactions to file.
2025-06-27T15:17:55Z Dumped mempool: 0.000s to copy, 0.028s to dump, 27 bytes dumped to file
2025-06-27T15:17:55Z Flushed fee estimates to fee_estimates.dat.
2025-06-27T15:17:57Z Shutdown: done
i have now tried evry posible thing to get my node back up running , i uninstalled evry app conected to bitcoin core moved the chainstate and blocks folder , uninstalled bitcoin core and reinstalled it , now the node worked fine i got peers connecting and my node was synched to 94% and downloading the remaining blocks , but once reaching 98% the node crashes again , and i get the same error as before ,
2025-06-27T23:43:09Z [error] ReadBlock: Deserialize or I/O error - ReadCompactSize(): size too large: iostream error at FlatFilePos(nFile=7, nPos=3828080)
2025-06-27T23:43:09Z [error] A fatal internal error occurred, see debug.log for details: Sync: Failed to read block 00000000000004d0c1c3f3a35807792019bc4a414801843055db5ede1d637405 from disk
2025-06-27T23:43:10Z [i2p:error] Couldn’t listen: Receive interrupted (received 0 bytes without terminator before that)
looks like i moved on and downloaded bitcoin-knots this node works fine with the same chainstate and blocks folder ,
I’d recommend to do a filesystem check, likely your SSD is toast.
Try to get it out and connect to a linux system, sudo fsck -y /dev/sdXn to validate, but as said, it looks like you have bad blocks on it and I would look for a swap as early as possible.
