Jellyfin app performance and shutdown issues
Hello,
I am addressing an issue that occurred while using the Jellyfin application on my server. After watching movies for two minutes, the system becomes unresponsive and then unreachable even via SSH. I suspect the problem may be related to my hardware. I’m using an Raspberry Pi 4 Argon One V2 case with an M.2 SATA SSD connected via USB 3.0. Could these components cause this type of system behavior? And if so, what could be the solutions?
Thank you for your help.
Model SSD NETAC N535N 2ТБ
