Hi, guys,
in debian 12 my umbrel wasn´t starting automatically so I’ve tried to fix this behavior making changes in
‘umbrel-startup.service’ that didn’t worked. The file exists on ‘/etc/systemd/system’ on debian. Could anyone post the content of this file here as I think there is some change that I couldn’t revert ? The file is a unit of systemd. I can’t also access the main page of umbrel.
Thanks in advance.
Here goes the debug info:
0.5.4
total usada livre compart. buff/cache disponível
Mem.: 33G 1,1G 31G 8,1M 734M 31G
Swap: 0B 0B 0B
total: 3,4%
thunderhub: 0%
system: %
ride-the-lightning: 0%
nextcloud: 0%
lightning: 0%
electrs: 0%
btc-rpc-explorer: 0%
bluewallet: 0%
bitcoin: 0%
Memory monitor logs
2023-10-24 10:22:41 Memory monitor running!
2023-10-24 10:22:52 Memory monitor running!
2023-10-24 10:23:03 Memory monitor running!
2023-10-24 10:23:14 Memory monitor running!
2023-10-24 10:23:25 Memory monitor running!
2023-10-24 10:23:36 Memory monitor running!
2023-10-24 10:23:47 Memory monitor running!
2023-10-24 10:23:57 Memory monitor running!
2023-10-24 10:24:08 Memory monitor running!
2023-10-24 10:24:19 Memory monitor running!
Sist. Arq. Tam. Usado Disp. Uso% Montado em
/dev/nvme0n1p2 938G 667G 224G 75% /
Karen logs
karen is running in /home/mauriciomota/umbrel/events
Docker containers
NAMES STATUS
manager Up 56 seconds
auth Up 56 seconds
Umbrel logs
Attaching to manager
manager | yarn run v1.22.18
manager | $ node ./bin/www
manager | Tue, 24 Oct 2023 13:31:25 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 13:31:25 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Listening on port 3006
manager | Tue, 24 Oct 2023 13:36:42 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 13:36:42 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Tue, 24 Oct 2023 13:53:20 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 13:53:20 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Tue, 24 Oct 2023 14:12:21 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 14:12:21 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Tue, 24 Oct 2023 14:17:08 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 14:17:08 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Tue, 24 Oct 2023 18:17:19 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Tue, 24 Oct 2023 18:17:19 GMT morgan deprecated default format: use combined format at app.js:49:9
Tor Proxy logs
Attaching to tor_proxy
App logs
bitcoin
Attaching to
bluewallet
Attaching to
btc-rpc-explorer
Attaching to
electrs
Attaching to
lightning
Attaching to
nextcloud
Attaching to
ride-the-lightning
Attaching to
thunderhub
Attaching to
==== Result ====
==== END =====
