Hello ,
my Umbrel 0.5.1 does not start because it has again the error message as described below in the log.
What can I do.
Startup service logs
Aug 10 16:53:46 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Aug 10 16:53:46 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Aug 10 16:53:46 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Aug 10 16:53:56 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Aug 10 16:53:56 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 103.
Aug 10 16:53:56 umbrel systemd[1]: Stopped Umbrel Startup Service.
Aug 10 16:53:56 umbrel systemd[1]: Starting Umbrel Startup Service…
Aug 10 16:53:56 umbrel umbrel startup[13307]: ======================================
Aug 10 16:53:56 umbrel umbrel startup[13307]: ============= STARTING ===============
Aug 10 16:53:56 umbrel umbrel startup[13307]: ============== UMBREL ================
Aug 10 16:53:56 umbrel umbrel startup[13307]: Setting environment variables…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting karen…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting status monitors…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting memory monitor…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting backup monitor…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting decoy backup trigger…
Aug 10 16:53:56 umbrel umbrel startup[13307]: Starting Docker services…
Aug 10 16:53:58 umbrel umbrel startup[13307]: auth is up-to-date
Aug 10 16:53:58 umbrel umbrel startup[13307]: Starting tor …
Aug 10 16:53:58 umbrel umbrel startup[13307]: dashboard is up-to-date
Aug 10 16:53:58 umbrel umbrel startup[13307]: Host is already in use by another container
Aug 10 16:53:58 umbrel umbrel startup[13307]: Starting tor … error
Aug 10 16:53:58 umbrel umbrel startup[13307]: ERROR: for tor Cannot start service tor_proxy: driver failed programming external connectivity on endpoint tor (1539bbe1a7c830a77836bedf9e4ede8b3c4f002beb6947c2da23f8e442f93710): Error starting userland proxy: listen tcp4 127.0.0.1:9050: bind: address already in use
Aug 10 16:53:58 umbrel umbrel startup[13307]: ERROR: for tor_proxy Cannot start service tor_proxy: driver failed programming external connectivity on endpoint tor (1539bbe1a7c830a77836bedf9e4ede8b3c4f002beb6947c2da23f8e442f93710): Error starting userland proxy: listen tcp4 127.0.0.1:9050: bind: address already in use
Aug 10 16:53:58 umbrel umbrel startup[13307]: Encountered errors while bringing up the project.
Aug 10 16:53:59 umbrel umbrel startup[13307]: Failed to start containers
Aug 10 16:53:59 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Aug 10 16:53:59 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Aug 10 16:53:59 umbrel systemd[1]: Failed to start Umbrel Startup Service.
