Intermittent node connection
Hi, since the new release of the bitcoin node’s software my connections are intermittent with other nodes. The blockchain takes ages to sync and I get a lot of 0 connections intervals. I try with core and knots and both of them do the same. I’m using a raspberry pi 5 with a 4 tb USB hdd. Is there any changes that they do to the new implementations? I would appreciate any help provided.
I successfully sync the blockchain. But the electrum server didn’t work (it doesn’t synchronize if the bitcoin node is not connected). So I reindex the blockchain to fix the connection problem. So now I’m with a 20% synchronization and it has been up 13 days.
I hope I explained myself…
Thank you in advance fo the help again.
