Installing umbrelOS on which x86 system
Hello, could you help me, I did the installation for any X86 system, but when I test on one of my computers, it works normally, but when I test on another machine, it doesn’t start, the system doesn’t start, do I have to make some adjustment to the machine’s bios to run properly?
The machine should support UEFI and basically that’s it, you can connect your computer to a display to see what is actually happening.
