Hey there,
Currently running a common Raspberry Pi 8GB with:
- M09 SATA Expansion Board
- 1TB SSD
- Custom Machined HeatSink
- 16 GB Micro SD Card for UmbrelOS (latest stable version)
When trying to install CLN I notice that it automatically create a new node, it’s NOT what. I’d like to import another existing node into the same hardware as I noticed that Umbrel allows to run two nodes at the same time. The above mentioned hardware it’s currently hosting a LND node only with few other Bitcoin and LND related applications.
What are the risks on doing it?
Does anyone know how I could successfully complete the import?
Thanks
