Ive searched around a bit and haven’t found anything useful.
Hey @Username1!
Could you try to stop Umbrel via the Stopping script?
sudo ~/umbrel/scripts/stop
then provide the output of the docker ps command:
docker ps
and try to start Umbrel again using the Starting script.
sudo ~/umbrel/scripts/start
If it didn’t work it may be worth having a look at the debug script output:
sudo ~/umbrel/scripts/debug
Keep us posted
When I do ‘docker ps’ without sudo, I get permission denied.
Alright! The stopping script shutdown everything normally, I don’t see any container left running after it,
So something is messing with ngninx at the startup, could you provide the full debug logs? (even if it says that there are no issues detected)
I couldn’t send the debug logs through a txt file. So I apologize for the pile of text.
0.5.1
Mem: 7.8G 5.8G 261M 434M 1.8G 1.3G
Swap: 976M 377M 599M
total: 74.1%
system: 73.8%
tor: 0.3%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2004 pts/1 S 0:00 bash ./scripts/memory-monitor
2004 ? S 0:00 bash ./scripts/memory-monitor
/dev/nvme0n1p2 28G 9.3G 17G 36% /
/dev/nvme0n1p4 200G 363M 189G 1% /home
Karen logs
2003 pts/1 S 0:00 bash ./karen
karen is already running
1988 pts/1 S 0:00 bash ./karen
1988 ? S 0:00 bash ./karen
2003 ? S 0:00 bash ./karen
Docker containers
NAMES STATUS
manager Up 17 hours
dashboard Up 17 hours
auth Up 17 hours
tor Up 17 hours
Umbrel logs
Attaching to manager
manager | yarn run v1.22.18
manager | $ node ./bin/www
manager | Wed, 28 Sep 2022 00:51:51 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:48:9
manager | Wed, 28 Sep 2022 00:51:51 GMT morgan deprecated default format: use combined format at app.js:48:9
manager | Listening on port 3006
Tor logs
Attaching to tor
tor | Sep 28 06:51:51.000 [notice] Heartbeat: Our onion services received 0 v3 INTRODUCE2 cells and attempted to launch 0 rendezvous circuits.
tor | Sep 28 07:01:05.000 [notice] No circuits are opened. Relaxed timeout for circuit 541 (a Measuring circuit timeout 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [3 similar message(s) suppressed in last 4260 seconds]
tor | Sep 28 08:51:02.000 [notice] No circuits are opened. Relaxed timeout for circuit 810 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [12 similar message(s) suppressed in last 6600 seconds]
tor | Sep 28 10:22:45.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 692 buildtimes.
tor | Sep 28 12:51:51.000 [notice] Heartbeat: Tor’s uptime is 12:00 hours, with 19 circuits open. I’ve sent 11.20 MB and received 13.54 MB. I’ve received 0 connections on IPv4 and 0 on IPv6. I’ve made 13 connections with IPv4 and 0 with IPv6.
tor | Sep 28 12:51:51.000 [notice] While bootstrapping, fetched this many bytes: 607770 (consensus network-status fetch); 28196 (authority cert fetch); 5087204 (microdescriptor fetch)
tor | Sep 28 12:51:51.000 [notice] While not bootstrapping, fetched this many bytes: 327267 (consensus network-status fetch); 111536 (microdescriptor fetch)
tor | Sep 28 12:51:51.000 [notice] Heartbeat: Our onion services received 0 v3 INTRODUCE2 cells and attempted to launch 0 rendezvous circuits.
tor | Sep 28 15:09:59.000 [notice] No circuits are opened. Relaxed timeout for circuit 1317 (a Measuring circuit timeout 3-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 22740 seconds]
tor | Sep 28 16:30:17.000 [notice] No circuits are opened. Relaxed timeout for circuit 1482 (a Measuring circuit timeout 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [13 similar message(s) suppressed in last 4860 seconds]
==== Result ====
Good News!
I found out what the issue was!
For me the application apache2 was taking up port 80. I just needed to modify which port apache2 takes. I hope this helps someone out in the future!
Thanks for the insight. How did you modify Apache2 port? And which port would you recommend to use instead of 80? I tried to google a solution and could not confirm that apach2 was even running on my machine. Thx
