Can someone help me to start with Umbrel OS? After installation i am only getting the apach2 start page. Debug log:
root@umbrelos:~# sudo ~/umbrel/scripts/debug
0.5.4
Mem: 4.3G 390M 3.1G 557K 795M 3.9G
Swap: 536M 0B 536M
total: 9.2%
system: 9.2%
Memory monitor logs
2023-10-22 12:58:06 Memory monitor running!
6304 ? S 0:00 bash ./scripts/memory-monitor
2023-10-22 13:00:33 Memory monitor running!
2023-10-22 13:18:13 Memory monitor running!
478 ? S 0:00 bash ./scripts/memory-monitor
/dev/mapper/pve-vm–203–disk–0 59G 2.7G 54G 5% /
Karen logs
karen is running in /root/umbrel/events
Got signal:
karen is getting triggered!
./karen: line 75: /root/umbrel/events/triggers/: Is a directory
Got signal:
6290 ? S 0:00 bash ./karen
6309 ? S 0:00 bash ./karen
karen is already running
Got signal:
Got signal:
Got signal:
Got signal:
464 ? S 0:00 bash ./karen
480 ? S 0:00 bash ./karen
Docker containers
NAMES STATUS
nginx Up 9 minutes
auth Up 9 minutes
manager Up 9 minutes
tor_proxy Up 9 minutes
dashboard Up 9 minutes
Umbrel logs
Attaching to manager
manager | yarn run v1.22.18
manager | $ node ./bin/www
manager | Sun, 22 Oct 2023 11:18:28 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Sun, 22 Oct 2023 11:18:28 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Listening on port 3006
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Oct 22 11:18:30.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 11:18:30.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 11:18:30.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 11:18:30.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Oct 22 11:18:31.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
==== END =====
