Password not recognised
Also my node said “syncing” since the last upgrade. My memory usage jumped to almost a terabyte with no apps running. Debug file here- https://pastebin.com/raw/7SDp1SHy
I am lost
ty in advance!
What is the ssh line that you are using?
Copy paste the Umbrel password you are using in the browser into the ssh prompt for password.
Sounded like the ticket, but didn’t work.
Read in troubleshooting manual the section about bad shutdown, the node is not syncing.
