How to update to umbrelOS 1.0
My node No longer lights up
I hope I haven’t lost my Bitcoins on my lnd
Now my bitcoin core is “not running”
Hey @Renanean, I’ll DM you my contact details through this platform. I can help troubleshoot.
After flashing 1.0.1 I can not even connect to umbrel??
Thanks a lot to @nmfretz For the time he spent with me. Everything is back to normal. Thank you so much
Hi @Satan_C just to confirm, your Raspberry Pi is connected to your local network via ethernet and you used http://umbrel.local/ in your browser?
I would suggest downloading angryip.org or fing.com, which will easily allow you to find your Umbrel’s IP, then you can just enter that in the browser. If this issue persists, please feel free to send a message to our support chat at umbrel.com or support@umbrel.com
Any update on the LND issue? The lightning node will not start. There is currently no way to recover lightning channels. Maybe my mistake, but I have a significant amount of money out there
I can’t even go back to 05.4 because I am not able to ssh into my node. My old password doesn’t work and “umbrel” doesn’t work. What is the ssh password after reflashing to 05.4? There has to be some way to recover the channels.
Don’t you meen 1.0? … I’m using a Raspberry Pi 4.
Hi @Hasher apologies for any confusion, the steps outlined here use a patched version of 1.0 which is 1.0.1 if you could please try them with your Pi device.
Hi @nneelis sorry to hear about your issue here. Can you please right-click on the lightning app, select restart and then navigate to the settings dashboard on umbrel.local, select START under troubleshooting before sharing the resultant logs here (or with our support chat on umbrel.com / support@umbrel.com).
And please don’t think that I’m forgetting the others from the umbrel team.
You all do a great job with all the mistakes and solutions!
I’m waiting for the rollout for other plattforms to try it in my orangepi. :slight_smile:
Deletion of data.
After updating to 1.01, the SSD could not be accessed at all. With 1.0 only LND no longer worked…
With support help (thanks again) it was determined that the file system on the SSD simply no longer worked. fshk
Now it was reformatted and 1.01 started. LND re-established with the 24 words. Channel backup only works after sync.
The BTC synchronization was not working this morning.
After a restart (clean restart from the menu) the umbrella was completely empty again? (no apps, wallet should be restored)
How can that be?
How can you query various status data on the console? Like web interface is only nice if everything works :slight_smile:
My bad, still not working
I have the intermittent problem of Umbrel not seeing the SSD. I have spent over two days downloading the blockchain and it is finally finished. I am not interested in installing a patch until I know with some degree of confidence that I will have access to the freshly downloaded blockchain. I will let others do your beta testing. This 1.0 should never have been released.
Hi @lukechilds
If I buy a new SD card to flash Umbrel 1.0 and got problems, I can just simple insert the old one (0.5.4) and it will be restored to the old state?
I don’t think so
In the same boat :frowning:
I’m half way threw my four day download. Should I wait till it’s done before flashing 1.0.1 to my microSD?
