Hi, how do you uninstall apps in Umbrel 0.5.3?
Welcome
At the bottom of your home screen in the web browser right above the settings cog wheel is a button that says manage apps.
Click that.
After you click that button red checks will appear in the corners of all your installed apps.
Click the ones you want to delete.
once done click done.
Your unwanted apps will now be removed.
