How to stop loosing SATs or I'm closing my node
I have had a node for several years now and have noticed that I am not earning any SATs instead I m loosing them.
I will move to a hard wallet if I cannot stop the leak and just close the node.
Any ideas on identifying the cause and turning it around?
Thank you
Hmm… To stop losing Sats, review your node settings: adjust routing fees, avoid inefficient rebalancing, and close unprofitable channels. Use tools like ThunderHub from Umbrel AppStore to monitor activity and optimize performance.
Hi @denny
I found in Lightening Node app under advanced settings, “base forwarding fee” and “forwarding fee rate”.
What are the recommended msats and ppm amounts?
I had 1000 in msats and 1 in ppm.
Thank you
