How to run commands on the umbrel (or just replace peers.dat)
so I identified the problem (replacing the peers.dat file to get the Bitcoin Node showing again), identified the code I have to probably be running
sudo ~/umbrel/scripts/app/stop bitcoin
rm ~/umbrel/app-data/bitcoin/data/bitcoin/peers.dat
but I have no idea how to do that. How can I access the files on the umbrel or run those commands there? the cmd app doesn’t seem to do anything (the umbrel is under 192.168…) and doesn’t even recognize the sudo command.
Someone please help with a step by step?
Thanks
When you log into Umbrel, click on the setting icon next to the app icon at the bottom of the main page. Toward the bottom of the Settings page, there is Advanced Settings. To the right of Advanced settings, click Open, then under the Terminal, click Open and select the area.
Thanks. However, there is no Advanced settings, see screenshot. That might be because I haven’t upgraded to 1.0 yet?
