Hello All,
Can anyone please tell me how I can run chantools in Umbrel?
I realize that I can download chantools from the link above but how do I install it to use in Umbrel
Thank you.
Orange Bonzo
Hello All,
Thank you.
Orange Bonzo
Unzip it
tar -zxvf chantools-linux-arm64-v0.10.1.tar.gz
Move it to your bin so you can call it
mv chantools-*/chantools /usr/local/bin
Then you should be able to use commands starting with chantools
chantools --help
Hi Moogdummy
Appreciate the tip!
Thank you heaps.
Orange_Bonzo
Iâm trying to install chantools in Umbrel too, I get this issue, any Idea? I installed the windows 386 version as I run a Windows 10 PC
umbrel@umbrel:/tmp $ tar -zxvf chantools.tar.gz
gzip: stdin has more than one entryârest ignored
tar: Child returned status 2
tar: Error is not recoverable: exiting now
umbrel@umbrel:/tmp $ sudo mv chantools-*/chantools /usr/local/bin/
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for umbrel:
mv: cannot stat âchantools-*/chantoolsâ: No such file or directory
Hi, Sorry just saw your post today as there was no notification sent to my email?
Create a github account and then post your question above to this github page.
I am sure one of the developers there would be glad to help you.
Best of luck
Orange
Any luck?
