How to querry my node via umbrel
I used to be able to querry my node to get all kindness useful info..it suddenly doesn’t work anymore..I even tried using the “advanced option” cli in knots..but everytime says 127.0.0.1:8333 is unreachable.
Did you do any setup in your router to always resolve your Umbrel to that IP address? If not, then periodically your router may change which IP your Umbrel is at.
Does going to http://127.0.0.1 take you to your umbrelOS web page? If not then you need to figure out which IP address your Umbrel on. If http://umbrel.local works to get to your umbrelOS webpage, then you could use umbrel.local:8333 to query it.
I know where my umbrel is at: 192.168.4.39..but..and no 127.0.0.1 doest lead to my umbrel..I really don’t get it bc i used to be able to get node info via cli
Btw how do I use umbrel.local:9333 to querry my node..
Ah I realized I made a mistake originally. 127.0.0.1 is the IP for “this machine” that you query from. Do you normally query by the command line or do you do it from a web interface?
I think the first place to start is to confirm the port number its on if its saying its unreachable. Have you tried restarting the apps involved with it?
