Say I wanted to free some funds back onto my BTC core wallet, what’s the best way to do that?
The swap feature in Thunderhub perhaps?
Well, if you spend BTC opening lightning channels from a on-chain wallet, then just close the lightning channels to get them back to the on-chain wallet, obviouslly. Sorry if I didnt get what you mean…
Ok, that makes sense.
Closing channels comes with a cost, as does swap via bolts.
Guess I need to compare what’s cheapest.
Another alternative is to send lightning to a wallet in Muun. Then you can transparently spend those BTC on-chain or on lightning from the Muun wallet. Ofc you will then put trust on their service, but it’s still non-custodial.
Not sure how they do their magic ![]()
