How to do a clean Unbrel node install
After almost 3 days of not being able to connect my node to umbrel.local. I have tried ssh, reflash microcard, etc I don’t see my umbrel on my router congig on the ethernet port.
Am i missing something
Would someone please help me start from zero so I can enjoy this umbrel node like it was meant to be.
Since aparently whenever I first installed it it worked flawlesly
My mistake was to shut it down correctly, but makes me wonder if the same would happen if the power goes out.
Thanks
you can find how to reset your user data here.
