How do I get my BTC from umbrel?
The shit has hit the fan , my umbrel is dead and Im desperate to recover my funds …
How do I get my BTC from umbrel if I only have the 24 words and dont have access to the lightning channel backup ?
I put the words into blue wallet but the balance is not the balance it should be
Im shitting myself
Is my life savings gone !!!
What was your umbrel made of ? PI4?
It would maybe worth to bring it back alive. how did it died. what do you see
recently upgraded to pi5 , then with the latest umbrel update bitcoin onchain was not loading / syncing
i reflashed the sd card three times , using different cards also
So i just could not get umbrel running properly again …
How ?
you a scammer
Hey @ant1356. Sorry to hear that. Don’t worry, the Lightning Node app on umbrelOS makes encrypted cloud backups of your channel backup file. But as @champs pointed out, you’ll need to run an Umbrel again.
I suggest trying both Pi 4 and Pi 5 to run umbrelOS, with the goal of just getting Bitcoin node synced no matter what the underlying hardware is, and then going through the funds recovery using the Lightning Node app. Here’s a demo of how the Lightning node recovery will look like.
Hi did you manage to get it up and running again ?
i had the same problem and solved by installing umbrel on my windows machine and then copying the whole /umbrel folder from the ssd from my crashed umbrel to the ubuntu on my windows machine.
What i did:
  • i connected my v-nand ssd from my umbrel node to my windows pc using a usb adapter.
  • installed wsl with ubuntu on my windows machine
  • attached the v-nand ssd to wsl ubuntu with usbipd
  • mounted the v-nand ssd in wsl ubuntu
  • installed umbrel (used exactly the same umbrel version as present on the v-nand ssd) in wsl ubuntu with the manual from this page: Installing Umbrel on Ubuntu 20.04 · GitHub
  • before running /scripts/start i rsynced the whole /umbrel folder from the ssd to the /umbrel folder in ubuntu (so not just the bitcoin folders)
  • ran /scripts/start
  • logged in on the webpage with my old password from the crashed umbrel node
  • bitcoin started running and is now synced
If you need help just reach out to umbrel@goeij.eu
