I assembled my Umbrel node and set up with 1TB SDD and I have its seed phrase saved. Then I changed the 1TB SDD to 2TB HDD and tried to login to my umbrel. I didn’t see option to select existing account, so I entered my previous email & used the same password when prompted for password. Then it gave me a new set of seed phrase which I wrote down and saved. Then, it took like a week to syn and when finished, I noticed that it was a new account. Now how can I access to my old Umbrel Wallet and get my money?
I was told to run
ssh -t umbrel@umbrel.local “sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/lnd/!(lnd.conf) && sudo rm -f ~/umbrel/db/user.json && sudo rm -f ~/umbrel/db/umbrel-seed/seed && sudo systemctl start umbrel-startup”
But it was giving me the following syntax error:
bash: -c: line 0: syntax error near unexpected token (' bash: -c: line 0: sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/lnd/!(lnd.conf) && sudo rm -f ~/umbrel/db/user.json && sudo rm -f ~/umbrel/db/umbrel-seed/seed && sudo systemctl start umbrel-startup’
I would appreciate your help to access my old Wallet and get my money.
