Hello I recently set up my Raspi 4 with UmbrelOS and when I go to log into the dashboard, I’m met with an infinite white loading screen saying, “Starting Umbrel” that never loads. I’ve tried unplugging, replugging the Raspi, and reflashing the SD; all of which fail to work.
I’ve also ran Angry IP and see that the Raspi and Umbrel are connected and showing an open channel, I even paste the direct IP into the URL bar only to meet the same loading screen. I’m a noob at this so please be thorough if the solution is at all complicated. Thank you for any help!
