Hello, my node became very sluggish, Elements used all RAM
after several reloads i saw that Elements app was taking up all the ram, I tried to connect by ssh and after half an hour of waiting it connected, but was very slow to write any commands and sudo reboot did not do anything, after some time i decided to hard reset, i managed to get it uop and running again and uninstalled Elements.
This is my debug data, maybe someone can tell me what happend and how to avoi happening again
0.5.3
Mem: 7.8G 1.2G 4.5G 34M 2.1G 6.3G
Swap: 4.1G 55M 4.0G
total: 15.9%
system: 15.9%
snowflake: 0%
bitfeed: 0%
bitcoin: 0%
Memory monitor logs
2023-01-08 22:14:52 Warning memory usage at 95%
2023-01-08 22:15:58 Warning memory usage at 95%
2023-01-08 22:17:07 Warning memory usage at 95%
2023-01-08 22:18:48 Warning memory usage at 95%
2023-01-08 22:21:02 Warning memory usage at 95%
2023-01-08 22:22:44 Warning memory usage at 95%
2023-01-08 22:25:23 Warning memory usage at 95%
2023-01-08 22:30:53 Warning memory usage at 95%
2023-01-08 22:33:00 Warning memory usage at 95%
2023-01-08 23:12:45 Memory monitor running!
/dev/mapper/ubuntu–vg-ubuntu–lv 937G 538G 360G 60% /
Karen logs
File “compose/cli/docker_client.py”, line 43, in get_client
File “compose/cli/docker_client.py”, line 170, in docker_client
File “docker/api/client.py”, line 197, in init
File “docker/api/client.py”, line 222, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=240)
karen is running in /home/tedulus/umbrel/events
Got signal:
karen is getting triggered!
./karen: line 75: /home/tedulus/umbrel/events/triggers/: Is a directory
Got signal:
Got signal: change-password
This script must only be run on Umbrel OS
Got signal: app-uninstall-elements
Removing images for app elements…
Stopping elements_web_1 …
Stopping elements_tor_1 …
Stopping elements_app_proxy_1 …
Stopping elements_node_1 …
Stopping elements_tor_server_1 …
Stopping elements_web_1 … done
Stopping elements_app_proxy_1 … done
Stopping elements_tor_1 … done
Stopping elements_node_1 … done
Stopping elements_tor_server_1 … done
Removing elements_web_1 …
Removing elements_tor_1 …
Removing elements_app_proxy_1 …
Removing elements_node_1 …
Removing elements_tor_server_1 …
Removing elements_web_1 … done
Removing elements_tor_server_1 … done
Removing elements_tor_1 … done
Removing elements_node_1 … done
Removing elements_app_proxy_1 … done
Network umbrel_main_network is external, skipping
Removing image ghcr.io/vulpemventures/elements:0.21.0.2@sha256:60f082b13b366743ef3cd113cb20397b586fd7032c0eb9c0a2a242ebc528f537
Removing image ghcr.io/tiero/elements-web:v0.0.3@sha256:b80dc0df2a4693668a97b874aad6d0a8d3239d03f4d05b4342600166934d0b87
Removing image getumbrel/tor:0.4.7.8@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a
Failed to remove image for service tor: 409 Client Error for http+docker://localhost/v1.41/images/getumbrel/tor:0.4.7.8%40sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a?force=False&noprune=False: Conflict (“conflict: unable to remove repository reference “getumbrel/tor:0.4.7.8@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a” (must force) - container e4a39dec9f30 is using its referenced image b3f3dff13ac2”)
Removing image getumbrel/app-proxy:v0.5.2@sha256:a2e3e0ddfcf84838bf0ba66f4b839ec958832d51f0ac9ace47962459c838b2d6
Failed to remove image for service app_proxy: 409 Client Error for http+docker://localhost/v1.41/images/getumbrel/app-proxy:v0.5.2%40sha256:a2e3e0ddfcf84838bf0ba66f4b839ec958832d51f0ac9ace47962459c838b2d6?force=False&noprune=False: Conflict (“conflict: unable to remove repository reference “getumbrel/app-proxy:v0.5.2@sha256:a2e3e0ddfcf84838bf0ba66f4b839ec958832d51f0ac9ace47962459c838b2d6” (must force) - container e498425d6512 is using its referenced image ca53932ff8f1”)
Failed to remove image for service tor_server: 409 Client Error for http+docker://localhost/v1.41/images/getumbrel/tor:0.4.7.8%40sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a?force=False&noprune=False: Conflict (“conflict: unable to remove repository reference “getumbrel/tor:0.4.7.8@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a” (must force) - container 7ae065b881b2 is using its referenced image b3f3dff13ac2”)
Deleting app data for app elements…
Removing app elements from DB…
Successfully uninstalled app elements
Docker containers
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/json”: dial unix /var/run/docker.sock: connect: permission denied
Umbrel logs
File “urllib3/connectionpool.py”, line 677, in urlopen
File “urllib3/connectionpool.py”, line 392, in _make_request
File “http/client.py”, line 1277, in request
File “http/client.py”, line 1323, in _send_request
File “http/client.py”, line 1272, in endheaders
File “http/client.py”, line 1032, in _send_output
File “http/client.py”, line 972, in send
File “docker/transport/unixconn.py”, line 43, in connect
PermissionError: [Errno 13] Permission denied
During handling of the above exception, another exception occurred:
File “requests/adapters.py”, line 449, in send
File “urllib3/connectionpool.py”, line 727, in urlopen
File “urllib3/util/retry.py”, line 410, in increment
File “urllib3/packages/six.py”, line 734, in reraise
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
File “docker/api/client.py”, line 214, in _retrieve_server_version
File “docker/api/daemon.py”, line 181, in version
File “docker/utils/decorators.py”, line 46, in inner
File “docker/api/client.py”, line 237, in _get
File “requests/sessions.py”, line 543, in get
File “requests/sessions.py”, line 530, in request
File “requests/sessions.py”, line 643, in send
File “requests/adapters.py”, line 498, in send
requests.exceptions.ConnectionError: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
File “docker-compose”, line 3, in
File “compose/cli/main.py”, line 81, in main
File “compose/cli/main.py”, line 200, in perform_command
File “compose/cli/command.py”, line 70, in project_from_options
File “compose/cli/command.py”, line 153, in get_project
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
[15275] Failed to execute script docker-compose
Tor Proxy logs
[15280] Failed to execute script docker-compose
App logs
bitcoin
[15362] Failed to execute script docker-compose
bitfeed
[15436] Failed to execute script docker-compose
snowflake
[15509] Failed to execute script docker-compose
==== Result ====
