[GUIDE] Cloning or Migrating SSD/HDD (Windows)
Updated from 1 to 2 TB following the instructions and taking into account the extra “1”.
Thanks for the guide!
It seems that Was the culprit :
sudo growpart /dev/sda1 1
to the correct line of:
sudo growpart /dev/sda 1      ( <---- only one 1 )
Filesystem at /dev/sda1 is mounted on /mnt/data; on-line resizing required
old_desc_blocks = 117, new_desc_blocks = 233
The filesystem on /dev/sda1 is now 488378385 (4k) blocks long.
Worked a charm!
Now, I have my older UmbrelOS Pi4’s on larger SSD’s (2TB & 4TB) / a few Pi5’s running on Faster NVMe (2TB drives) over PoE+ hats.
This was the missing step to my problem(s) !
Nice work! =)
is it working also with 4TB ssd? i have read there may be issues…
Just confirming that it works flawlessly also with 4TB ssd. Used Macrium X
I got foolowed error:
umbrel@umbrel:~$ sudo growpart /dev/sda 1
sudo: growpart: command not found
Asked ChatGPT about that and it guided me to utilized the following command:
sudo apt update && sudo apt install cloud-guest-utils -y
Than run
and followed the rest of the tutorial…
Successfully upgraded from 1TB to 2TB.
Thanks for the tutorial.
Ondra.
Isn’t Windows autoformatting a newly attached hard drive?
hello
when doing sudo growpart /dev/sda1 1
return is
sudo: growpart command unknown
what is this thank you
As a newbie, you lost me at #12. Have no clue what you are saying. And what does ===== TL;DR: version ===== Stand for?
I appreciate your help, but can you simplify it for someone who doesn’t actually speak any of this lingo? Just a basic computer user?
My son in law helped me set it up a few years ago, but, they are going through some life issues and I don’t want to bother him for now.
Thanks in advance.
