So my Umbrel has been working away for 6 months or so, all recommended hardware, always online. Opened a lightning channel 2 weeks ago and had been using it to familiarise myself and using the BTCPay Server API for my Uni project.
Noticed that it wasn’t reachable yesterday, tried umbrel.local, tried an IP scan on my network, the usual. Both LEDs on the RPi board are on constant (not sure if that’s normal) and so are the two on the Ethernet port (usually the green one flashes w/ activity I think).
I took the SD card out and Windows wanted to format it, not sure if that’s normal, would have thought it would have been able to read it as is? Also plugged the SSD into windows machine and it didn’t come up in file explorer at all?
Does it sound like one some piece of hardware has broken?
Any help is much appreciated!
