Getting VLC on Umbrel
I want to install VLC on my Umbrel so that I can use it with Home Assistant and have music locally. I tried finding VLC on the store inside of umbrel, but I couldn’t find it. I know this uses docker so maybe I could adapt the Home Assistant add-on as a community store? Any help would be appreciated.
Have you checked this already? GitHub - getumbrel/umbrel-community-app-store: Template repository for a creating your own Community App Store for Umbrel. Click "Use this template" and add your apps!
Yeah I did and I got an app store running and it displays VLC now, but you can’t actually install it. Currently just goes immediately back to the install button after clicking it. Going to try and get it to work soon.
