I’ve seen this asked before, but no one answered the post. How do we install apps that are not in the app store? Thanks
Do you have an example of an app you’d like to install? If you want to create your own app store you can do so, and add your own dockerised apps.
However, may I suggest that if you want to add your own dockerised apps, that you consider submitting them to the Umbrel store too?
Yes i want to know too because i want to run a newpac usb miner for on my son’s umbrel (raspberry pi) (Newpac miner on umbrel)
I got no succes …block still 85 percent … You need two pi…one with the sticks extern power suply
You can add your own apps to Umbrel by using the Umbrel Community App Store Template. Here’s the link to the official page with all instructions: Umbrel Community App Store.
You can view all existing app stores here: Umbrel Community App Store Forks.
Maybe your app is listed there! ![]()
Isnt it a bit counter productive to have people create an entire store just to install an extra app?
