Fulcrum slow on umbrel OS 1.2.2 on Raspi5
I gave up on Electrum install as it appears to be a buggy version included in the app store.
I am trying Fulcrum but I see errors also:
umbrel@umbrel:~$ sudo docker logs 26ea3beb7572 | tail -50
Sat, 16 Nov 2024 12:09:38 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:28:9
Sat, 16 Nov 2024 12:09:38 GMT morgan deprecated default format: use combined format at app.js:28:9
version error: Error: connect ECONNREFUSED 10.21.21.200:50002
at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16) {
errno: -111,
code: ‘ECONNREFUSED’,
syscall: ‘connect’,
address: ‘10.21.21.200’,
port: 50002
syncPercent error: Error: connect ECONNREFUSED 10.21.21.200:50002
errno: -111,
syscall: ‘connect’,
port: 50002
and then, later in the log:
Electrum attempting reconnect…
forever.
Anybody know what’s causing this?
Also, at start of log for the “fulcrum_fulcrum_1” container:
[2024-11-16 12:09:36.397] Warning: rpcuser is specified both via the config file and the environement (as RPCUSER). The config file setting will take precendence.
[2024-11-16 12:09:36.397] Warning: rpcpassword is specified both via the config file and the environement (as RPCPASSWORD). The config file setting will take precendence.
[2024-11-16 12:09:36.397] Enabled JSON parser: simdjson
[2024-11-16 12:09:36.397] simdjson implementations:
[2024-11-16 12:09:36.397] fallback: Generic fallback implementation [supported]
[2024-11-16 12:09:36.397] active implementation: fallback
[2024-11-16 12:09:36.398] jemalloc: version 5.3.0-0-g54eaed1
[2024-11-16 12:09:36.398] Qt: version 5.15.13
[2024-11-16 12:09:36.398] rocksdb: version 9.2.1-08f9322
[2024-11-16 12:09:36.398] simdjson: version 0.6.0
[2024-11-16 12:09:36.398] ssl: OpenSSL 3.3.2 3 Sep 2024
[2024-11-16 12:09:36.398] zmq: libzmq version: 4.3.5, cppzmq version: 4.10.0
[2024-11-16 12:09:36.398] Fulcrum 1.11.1 (Release a1f6a54) - Sat Nov 16, 2024 12:09:36.398 UTC - starting up …
[2024-11-16 12:09:36.398] Max open files: 1048576
[2024-11-16 12:09:36.399] Loading database …
[2024-11-16 12:09:36.803] DB memory: 512.00 MiB
[2024-11-16 12:09:36.804] Verifying headers …
[2024-11-16 12:09:36.804] DB version: v3
[2024-11-16 12:09:36.804] BitcoinDMgr: starting 3 bitcoin RPC clients …
[2024-11-16 12:09:36.805] BitcoinDMgr: started ok
[2024-11-16 12:09:36.827] Coin: BTC
[2024-11-16 12:09:36.932] Chain: main
[2024-11-16 12:09:36.932] Block height 870562, downloading new blocks …
[2024-11-16 12:09:36.932] utxo-cache: Not enabled
It appears to have slowed down to a crawl now. Here’s the start of the log:
[2024-11-16 12:09:37.373] Processed height: 1000, 0.1%, 2269.8 blocks/sec, 2312.9 txs/sec, 2371.9 addrs/sec
[2024-11-16 12:09:37.731] Processed height: 2000, 0.2%, 2793.3 blocks/sec, 2824.0 txs/sec, 3044.7 addrs/sec
[2024-11-16 12:09:38.060] Processed height: 3000, 0.3%, 3039.5 blocks/sec, 3100.3 txs/sec, 3218.8 addrs/sec
[2024-11-16 12:09:38.379] Processed height: 4000, 0.5%, 3134.8 blocks/sec, 3159.9 txs/sec, 3416.9 addrs/sec
[2024-11-16 12:09:38.616] Processed height: 5000, 0.6%, 4219.4 blocks/sec, 4240.5 txs/sec, 4489.5 addrs/sec
[2024-11-16 12:09:38.798] Processed height: 6000, 0.7%, 5494.5 blocks/sec, 5527.5 txs/sec, 5818.7 addrs/sec
[2024-11-16 12:09:38.982] Processed height: 7000, 0.8%, 5434.8 blocks/sec, 5478.3 txs/sec, 5837.0 addrs/sec
[2024-11-16 12:09:39.168] Processed height: 8000, 0.9%, 5376.3 blocks/sec, 5403.2 txs/sec, 5817.2 addrs/sec
but now:
[2024-11-16 16:12:18.213] Processed height: 426000, 48.9%, 5.86 blocks/sec, 9157.5 txs/sec, 32013.6 addrs/sec
[2024-11-16 16:15:18.906] Processed height: 427000, 49.0%, 5.53 blocks/sec, 8344.8 txs/sec, 29715.9 addrs/sec
[2024-11-16 16:18:10.337] Processed height: 428000, 49.2%, 5.83 blocks/sec, 8663.9 txs/sec, 30784.8 addrs/sec
[2024-11-16 16:21:07.144] Processed height: 429000, 49.3%, 5.66 blocks/sec, 8398.8 txs/sec, 30576.6 addrs/sec
[2024-11-16 16:23:50.568] Processed height: 430000, 49.4%, 6.12 blocks/sec, 8298.3 txs/sec, 30840.2 addrs/sec
[2024-11-16 16:26:43.443] Processed height: 431000, 49.5%, 5.78 blocks/sec, 8549.9 txs/sec, 30714.5 addrs/sec
[2024-11-16 16:29:21.690] Processed height: 432000, 49.6%, 6.32 blocks/sec, 8990.5 txs/sec, 33298.1 addrs/sec
[2024-11-16 16:32:23.904] Processed height: 433000, 49.7%, 5.49 blocks/sec, 8736.6 txs/sec, 32614.7 addrs/sec
[2024-11-16 16:35:47.595] Processed height: 434000, 49.9%, 4.91 blocks/sec, 8180.5 txs/sec, 29934.5 addrs/sec
Can someone help me fix this? At this rate it will take about a week to finish indexing.
Is there some configuration I can tweak for this to speed it up?
I have 8G RAM and it’s only using less than half of it.
Did you ever have success with Fulcrum? I recently updated my Pi4/8GB setup with a 2TB HD and was able to do a clean install with Knots and Fulcrum, and although it took about two and a half weeks for everything to sync it works great now. It didn’t show any progress on the Fulcrum page during sync, so I had to keep checking the logs to make sure something was happening.
I did the clean install of Umbrel 1.2 and then a quick update to 1.4.2 before installing Fulcrum.
I tried it but it didn’t work and I resorted to electrumrs which works great.
