Hey all
Got a second WD_BLACK SN850X the other day and the Failsafe activation failed. I spent the last 2 days troubleshooting with ChatGPT and I finally managed to initialize Failsafe successfully.
Here’s a summary of what happened, with some suggestions for Umbrel’s devs at the bottom.
Umbrel Home UI Randomly Freezing, FailSafe Migration Failing, “Dataset Already Exists”, Inotify Errors, and Eventually Successful RAIDZ1 Migration
Summary
I wanted to enable FailSafe on my Umbrel Home using two identical WD_BLACK SN850X 8TB SSDs.
What started as a simple storage upgrade turned into a multi-day troubleshooting process involving:
Random Umbrel UI lockups
Dashboard becoming unreachable while apps remained operational
High CPU spikes
Suspected SSD overheating
Suspected hardware instability
FailSafe migration failures
ZFS snapshot errors
“dataset already exists” errors
Inotify watch failures
Umbrel dashboard getting stuck at 52%
RAID resilver monitoring
In the end:
FailSafe successfully enabled
RAIDZ1 created
Both 8TB SSDs healthy
ZFS pool healthy
No data loss
However, I believe there may still be an underlying Umbrel issue involving file watchers, Nextcloud previews, and inotify limits.
Environment
Hardware
Umbrel Home
16GB RAM
WD_BLACK SN850X 8TB (existing drive)
WD_BLACK SN850X 8TB (new drive)
Installed Apps
Bitcoin
Lightning
Electrs
BTC RPC Explorer
Nextcloud
OnlyOffice
AdGuard Home
Ollama
OpenClaw
Passky
Jellyfin
Other miscellaneous apps
Original Problem (Before Installing Second SSD)
The first symptom was not related to FailSafe at all.
Umbrel had become unstable.
Symptoms:
Dashboard frequently becoming unresponsive
Clicking buttons did nothing
Refreshing the page often resulted in a blank page
Sometimes the dashboard would not load at all
Apps remained functional
Nextcloud continued working
Bitcoin node continued working
This made the issue very strange because Umbrel itself appeared partially alive.
Initial Investigation
Checked:
free -h
top
sudo docker ps
sudo docker stats --no-stream
Findings:
CPU occasionally spiking above 80%
Memory usage elevated but not exhausted
Containers appeared healthy
Suspicion Falls on the Second SSD
At this point I had previously experimented with a second SN850X.
Observations:
The second SSD became extremely hot to the touch
Considerably hotter than the primary SSD
UI instability appeared worse with the second SSD installed
This led me to suspect:
NVMe overheating
PCIe issues
Hardware instability
First Major Discovery
Umbrel logs repeatedly contained:
No space left on device
along with:
inotify_add_watch failed
and
Failed to watch directory
This was the first indication that the issue might not be hardware-related at all.
Removing Unused Apps
As a test, I removed:
Canary
Several unused applications
Result:
CPU usage dropped
Umbrel became dramatically more stable
Dashboard remained responsive much longer
This was the first sign that resource exhaustion might be involved.
Reinstalling Second SSD
After stability improved, I reinstalled the second WD_BLACK SN850X.
Verification:
lsblk
Both drives detected.
SMART:
sudo smartctl -a /dev/nvme0
sudo smartctl -a /dev/nvme1
Results:
Critical Warning = 0x00
Percentage Used = 0%
No SMART errors
Temperatures:
~32°C
~38°C
Much cooler than originally suspected.
This largely eliminated hardware concerns.
Attempting FailSafe
FailSafe failed immediately.
Error:
cannot create snapshot 'umbrelos-d16679a1@migration':
ZFS Investigation
Checked:
zpool status
sudo zfs list
sudo zfs list -t snapshot
Results:
Pool healthy
No migration snapshot
No migration dataset
Yet FailSafe insisted:
Verifying ZFS Functionality
Manual snapshot test:
sudo zfs snapshot umbrelos-d16679a1@testsnapshot
sudo zfs destroy umbrelos-d16679a1@testsnapshot
All worked perfectly.
This proved:
ZFS healthy
Snapshot functionality healthy
Storage healthy
Discovering the Inotify Problem
Logs repeatedly showed:
inotify_add_watch ... failed:
Example:
/home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/data/appdata_xxxxx/preview/...
Notice this was inside:
Nextcloud preview cache
Increasing Inotify Limits
Current values:
cat /proc/sys/fs/inotify/max_user_watches
cat /proc/sys/fs/inotify/max_user_instances
Returned:
122404
256
We increased them:
echo "fs.inotify.max_user_watches=1048576" | sudo tee /etc/sysctl.d/99-inotify.conf
echo "fs.inotify.max_user_instances=1024" | sudo tee -a /etc/sysctl.d/99-inotify.conf
sudo sysctl --system
New values:
1048576
1024
FailSafe Suddenly Starts Working
After increasing the limits:
FailSafe progressed.
Dashboard showed:
Enabling FailSafe...
1%
Migration Progress
Migration advanced normally.
At approximately 50%:
Umbrel rebooted automatically.
This was expected behavior.
Dashboard Gets Stuck at 52%
After reboot:
Dashboard remained at:
52%
for a very long time.
Initially appeared stuck.
ZFS Reveals Reality
Running:
zpool status
showed:
scan: resilver in progress
and:
1.3 GB/s reads
1.3 GB/s writes
with:
36% done
The migration was continuing normally.
The UI simply wasn’t updating.
Migration Completes Successfully
Eventually:
zpool status
reported:
scan: resilvered 4.19T in 01:07:46 with 0 errors
Pool:
state: ONLINE
Configuration:
raidz1-0
SSD1 ONLINE
SSD2 ONLINE
Dashboard Still Broken
Even after migration completed:
Dashboard remained stuck
UI became unresponsive again
However:
Bitcoin worked
Nextcloud worked
Apps worked
This strongly suggested the problem was isolated to Umbrel itself.
Restarting Umbrel Service
Checked:
sudo systemctl status umbrel
Umbrel daemon healthy.
Restarted:
sudo systemctl restart umbrel
Dashboard returned.
Final Verification
ZFS
zpool status
Result:
pool: umbrelos-d16679a1
state: ONLINE
errors: No known data errors
SMART
Results:
Drive 1:
Critical Warning: 0x00
Temperature: 37°C
Percentage Used: 0%
Drive 2:
Temperature: 39°C
Percentage Used: 0%
Umbrel Dashboard
Storage Manager now shows:
16 TB Total Storage
8 TB Protected Storage
FailSafe Enabled
Remaining Concern
After reboot, the inotify values reverted:
returned:
122404
256
again.
Umbrel logs showed:
[files:watcher] Setting system inotify limits
which suggests Umbrel is overriding custom values.
The same error still appeared:
inside:
My Theory
I no longer believe the second SSD was ever the root cause.
Instead I suspect:
Umbrel Files is attempting to watch a massive Nextcloud preview tree.
Inotify limits are being exceeded.
This causes intermittent dashboard lockups.
The FailSafe migration process amplified the problem because it repeatedly restarted indexing and file scanning.
Questions for Umbrel Team
- Why does FailSafe sometimes fail with:
when no migration snapshot exists?
Why does Umbrel override manually configured inotify limits?
Is there a known issue with Umbrel Files indexing large Nextcloud preview caches?
Could inotify exhaustion explain:
dashboard freezes
UI lockups
partial dashboard loading
Is there a supported way to permanently increase:
on Umbrel Home?
Hopefully this helps someone else experiencing random dashboard lockups, FailSafe migration failures, or mysterious “No space left on device” errors despite having plenty of disk space available.
