Booting problem: System service failed
Hi everyone. After upgrade to 0.4.5 I’ve got an error, after that Umbrel can’t boot up.
Here is my logs. Please help me
umbrel@umbrel:~/umbrel $ ~/umbrel/scripts/debug --upload
0.4.4
Flashed OS version
v0.4.5
Raspberry Pi Model
Revision : d03114
Serial : 1000000088a27983
Firmware
Sep 30 2021 19:21:03
Copyright © 2012 Broadcom
version 51215b4f6e3966401ecd99652a35cf1c25069113 (clean) (release) (start)
Temperature
temp=47.2’C
Throttling
throttled=0x0
Mem: 7.8G 140M 7.4G 8.0M 293M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.8%
system: 1.8%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2021-10-26 01:41:01 Memory monitor running!
2021-10-26 01:41:15 Memory monitor running!
2021-10-26 01:41:30 Memory monitor running!
2021-10-26 01:41:44 Memory monitor running!
2021-10-26 01:41:58 Memory monitor running!
2021-10-26 01:42:13 Memory monitor running!
2021-10-26 01:42:27 Memory monitor running!
2021-10-26 01:42:41 Memory monitor running!
2021-10-26 01:42:56 Memory monitor running!
2021-10-26 01:30:54 Memory monitor running!
/dev/root 59G 3.0G 54G 6% /
/dev/sda1 916G 32G 838G 4% /home/umbrel/umbrel
Startup service logs
– Logs begin at Sun 2021-11-14 20:47:59 UTC, end at Sun 2021-11-14 20:50:47 UTC. –
Nov 14 20:48:17 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 14 20:48:17 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Nov 14 20:48:04 umbrel systemd[1]: Starting External Storage Mounter…
Nov 14 20:48:04 umbrel external storage mounter[488]: Running external storage mount script…
Nov 14 20:48:04 umbrel external storage mounter[488]: Found device “CT1000MX 500SSD1”
Nov 14 20:48:04 umbrel external storage mounter[488]: Blacklisting USB device IDs against UAS driver…
Nov 14 20:48:04 umbrel external storage mounter[488]: Rebinding USB drivers…
Nov 14 20:48:04 umbrel external storage mounter[488]: Checking USB devices are back…
Nov 14 20:48:04 umbrel external storage mounter[488]: Waiting for USB devices…
Nov 14 20:48:05 umbrel external storage mounter[488]: Waiting for USB devices…
Nov 14 20:48:06 umbrel external storage mounter[488]: Checking if the device is ext4…
Nov 14 20:48:07 umbrel external storage mounter[488]: Yes, it is ext4
Nov 14 20:48:07 umbrel external storage mounter[488]: Checking if device contains an Umbrel install…
Nov 14 20:48:07 umbrel external storage mounter[488]: Yes, it contains an Umbrel install
Nov 14 20:48:07 umbrel external storage mounter[488]: Bind mounting external storage over local Umbrel installation…
Nov 14 20:48:07 umbrel external storage mounter[488]: Bind mounting external storage over local Docker data dir…
Nov 14 20:48:07 umbrel external storage mounter[488]: Bind mounting external storage to /swap
Nov 14 20:48:07 umbrel external storage mounter[488]: Bind mounting SD card root at /sd-card…
Nov 14 20:48:07 umbrel external storage mounter[488]: Checking Umbrel root is now on external storage…
Nov 14 20:48:08 umbrel external storage mounter[488]: Checking /var/lib/docker is now on external storage…
Nov 14 20:48:08 umbrel external storage mounter[488]: Checking /swap is now on external storage…
Nov 14 20:48:08 umbrel external storage mounter[488]: Setting up swapfile
Nov 14 20:48:08 umbrel external storage mounter[488]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 14 20:48:08 umbrel external storage mounter[488]: no label, UUID=0a0a8acc-7b31-4995-aa4d-d67994bff5b0
Nov 14 20:48:08 umbrel external storage mounter[488]: Checking SD Card root is bind mounted at /sd-root…
Nov 14 20:48:08 umbrel external storage mounter[488]: Starting external drive mount monitor…
Nov 14 20:48:08 umbrel external storage mounter[488]: Mount script completed successfully!
Nov 14 20:48:08 umbrel systemd[1]: Started External Storage Mounter.
Nov 14 20:48:16 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 14 20:48:16 umbrel external storage updater[999]: Checking if SD card Umbrel is newer than external storage…
Nov 14 20:48:17 umbrel external storage updater[999]: Yes, SD version is newer.
Nov 14 20:48:17 umbrel external storage updater[999]: Checking if the external storage version “0.4.4” satisfies update requirement “>=0.2.1”…
Nov 14 20:48:17 umbrel external storage updater[999]: Yes, it does, attempting an automatic update…
Nov 14 20:48:17 umbrel external storage updater[999]: =======================================
Nov 14 20:48:17 umbrel external storage updater[999]: =============== UPDATE ================
Nov 14 20:48:17 umbrel external storage updater[999]: ========== Stage: Download ============
Nov 14 20:48:17 umbrel external storage updater[999]: An update is already in progress. Exiting now.
Nov 14 20:48:17 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Nov 14 20:48:17 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Failed with result ‘exit-code’.
Nov 14 20:48:17 umbrel systemd[1]: Failed to start External Storage SDcard Updater.
Karen logs
449 ? R 0:00 bash ./karen
450 ? R 0:00 bash ./karen
karen is already running
Docker containers
NAMES STATUS
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-10-26T02:51:58Z init message: Loading block index…
bitcoin | 2021-10-26T02:51:58Z Switching active chainstate to Chainstate [ibd] @ height -1 (null)
bitcoin | 2021-10-26T02:51:58Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoin | 2021-10-26T02:51:58Z Opened LevelDB successfully
bitcoin | 2021-10-26T02:51:58Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
bitcoin | 2021-10-26T02:52:11Z LoadBlockIndexDB: last block file = 143
bitcoin | 2021-10-26T02:52:11Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=470, size=119167307, heights=302411…302966, time=2014-05-24…2014-05-28)
bitcoin | 2021-10-26T02:52:11Z Checking all blk files are present…
bitcoin | 2021-10-26T02:52:11Z Opening LevelDB in /data/.bitcoin/chainstate
bitcoin | 2021-10-26T02:52:11Z Opened LevelDB successfully
bitcoin | 2021-10-26T02:52:13Z Using obfuscation key for /data/.bitcoin/chainstate: 4c1d6874a18d031e
bitcoin | 2021-10-26T02:52:14Z Loaded best chain: hashBestChain=00000000000000002033b076e13e955da9932627aa7d4749b2f2a1d2ffe69e35 height=302554 date=2014-05-25T12:08:11Z progress=0.058248
bitcoin | 2021-10-26T02:52:14Z init message: Verifying blocks…
bitcoin | 2021-10-26T02:52:14Z Verifying last 6 blocks at level 3
bitcoin | 2021-10-26T02:52:14Z [0%]…LevelDB read failure: Corruption: block checksum mismatch: /data/.bitcoin/chainstate/003554.ldb
bitcoin | 2021-10-26T02:52:20Z Fatal LevelDB error: Corruption: block checksum mismatch: /data/.bitcoin/chainstate/003554.ldb
bitcoin | 2021-10-26T02:52:20Z You can use -debug=leveldb to get more complete diagnostic messages
bitcoin | 2021-10-26T02:52:20Z : Error opening block database.
bitcoin | Please restart with -reindex or -reindex-chainstate to recover.
bitcoin | : Error opening block database.
bitcoin | 2021-10-26T02:52:20Z Aborted block database rebuild. Exiting.
bitcoin | 2021-10-26T02:52:20Z Shutdown: In progress…
bitcoin | 2021-10-26T02:52:20Z scheduler thread exit
bitcoin | 2021-10-26T02:52:20Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) started
bitcoin | 2021-10-26T02:52:20Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) completed (0.01s)
bitcoin | 2021-10-26T02:52:20Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) completed (0.00s)
bitcoin | 2021-10-26T02:52:22Z Shutdown: done
LND logs
Attaching to lnd
lnd | 2021-10-26 02:47:28.595 [INF] LTND: Version: 0.13.3-beta commit=v0.13.3-beta, build=production, logging=default, debuglevel=info
lnd | 2021-10-26 02:47:28.595 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-10-26 02:47:29.050 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:47:29.050 [INF] LTND: Shutdown complete
lnd |
lnd | unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:48:30.157 [INF] LTND: Version: 0.13.3-beta commit=v0.13.3-beta, build=production, logging=default, debuglevel=info
lnd | 2021-10-26 02:48:30.157 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-10-26 02:48:30.518 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:48:30.519 [INF] LTND: Shutdown complete
lnd |
lnd | 2021-10-26 02:49:31.638 [INF] LTND: Version: 0.13.3-beta commit=v0.13.3-beta, build=production, logging=default, debuglevel=info
lnd | 2021-10-26 02:49:31.638 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-10-26 02:49:32.011 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:49:32.012 [INF] LTND: Shutdown complete
lnd |
lnd | 2021-10-26 02:50:33.462 [INF] LTND: Version: 0.13.3-beta commit=v0.13.3-beta, build=production, logging=default, debuglevel=info
lnd | 2021-10-26 02:50:33.462 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-10-26 02:50:33.860 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:50:33.860 [INF] LTND: Shutdown complete
lnd |
lnd | 2021-10-26 02:51:35.335 [INF] LTND: Version: 0.13.3-beta commit=v0.13.3-beta, build=production, logging=default, debuglevel=info
lnd | 2021-10-26 02:51:35.336 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-10-26 02:51:35.686 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-10-26 02:51:35.687 [INF] LTND: Shutdown complete
lnd |
Tor logs
Attaching to tor
tor | Oct 26 01:30:54.000 [warn] Bug: tor(log_backtrace_impl+0x68) [0x5563f7bc20] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(tor_bug_occurred_+0x158) [0x5563f86f50] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(+0x68bb0) [0x5563ef8bb0] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(microdesc_cache_reload+0xcc) [0x5563efb24c] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(get_microdesc_cache+0x58) [0x5563efb340] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(nodelist_set_consensus+0x438) [0x5563f08de0] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(networkstatus_set_current_consensus+0x988) [0x5563f01048] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(+0x71324) [0x5563f01324] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(router_reload_consensus_networkstatus+0x58) [0x5563f013f0] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(run_tor_main_loop+0x90) [0x5563ef1820] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(tor_run_main+0xd4) [0x5563ef1c4c] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(tor_main+0x48) [0x5563ef05a8] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(main+0x24) [0x5563ef00d4] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: /lib/aarch64-linux-gnu/libc.so.6(__libc_start_main+0xe4) [0x7fa10c9d24] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] Bug: tor(+0x60130) [0x5563ef0130] (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] warn_if_nul_found(): Bug: Found unexpected NUL while reading microdesc journal, offset 0at position 1040676/1044480. (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] warn_if_nul_found(): Bug: surrounding string: 3779646A49322B4B664B396F6174450A00000000000000000000000000000000 (on Tor 0.4.5.7 )
tor | Oct 26 01:30:54.000 [warn] parse error: internal NUL character.
tor | Oct 26 01:30:54.000 [warn] Unparseable microdescriptor found in journal
tor | Oct 26 01:30:55.000 [notice] Starting with guard context “default”
tor | Oct 26 01:30:56.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor | Oct 26 01:30:56.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor | Oct 26 01:30:56.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor | Oct 26 01:30:57.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor | Oct 26 01:30:57.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | Oct 26 01:30:57.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | Oct 26 01:30:57.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | Oct 26 01:44:04.000 [notice] Your system clock just jumped 785 seconds forward; assuming established circuits no longer work.
tor | Oct 26 01:44:07.000 [notice] Bootstrapped 100% (done): Done
tor | Oct 26 01:44:31.000 [notice] Guard redsox ($E0A3471C24C9021CC58FBF774203046FD2BC893F) is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 165/236. Use counts are 85/85. 166 circuits completed, 0 were unusable, 1 collapsed, and 6 timed out. For reference, your timeout cutoff is 4560 seconds.
Did you read your own logs?
Are pretty clear. You have corrupted data.
Solution? re.index or wipe blocks and sync again
How I can do that?
Which exactly point is about re.index or wipe blocks?
Edit bitcoin.conf and add reindex=1
Let the node to start slowly doing its job.
Check the bitcoin logs with
SSH into umbrel
cd umbrel
docker-compose logs -f bitcoin
this will show you in real time what is doing.
Have patience, can take several days.
When you see it finished, will also take more hours for electrs to reindex the blocks.
When is done, stop the umbrel scripts and remove that reindex line.
Start umbrel. done
Thank you! It’s very complete instruction to reindex. And how I can wipe it? Maybe just wipe my ssd and make a new partition NTFS?
Nooo, never format NTFS.
To be sure that the disk will be OK, yes, is good to start over with a format, but not NTFS.
Umbrel is using ext4 format.
So just go and delete the partition but not create a new one. Umbrel install will do it itself in its format type in the process.
Just start over with a new installation as you did first time. Also wiping the mSD.
New wallet seed, new instance, fresh.
But remember, only if you have NO funds at all in that node.
Wiped SSD, wiped mSD, but umbrel.local just showing me that:
Screenshot from 2021-11-14 20-35-12
So no screen with setup user/pwd, save seed, nothing?
Damn, that means you have serious trouble with that SSD. Time to replace it.
Or check if your power source is original and OK. If the drive do not have enough power can get rekt.
Also USB cables/case can cause damage or bad connection to the drive.
Nothing. Now I’m seeing " Error: System service failed"
umbrel@umbrel:~ $ ~/umbrel/scripts/debug --upload
0.4.7
Flashed OS version
v0.4.7
Raspberry Pi Model
Revision : d03114
Firmware
Oct 29 2021 10:47:33
Copyright (c) 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=48.2’C
Throttling
throttled=0x0
Mem: 7.8G 128M 7.1G 8.0M 586M 7.6G
Swap: 0B 0B 0B
total: 1.6%
system: 1.6%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
tail: cannot open ‘/home/umbrel/umbrel/scripts/../logs/memory-monitor.log’ for reading: No such file or directory
– Logs begin at Mon 2021-11-15 06:17:01 UTC, end at Wed 2021-11-17 17:00:12 UTC. –
Nov 17 16:08:00 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 17 16:08:00 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/9a10e0dcf646369d825273e2180109a51a93fdeec161a995072c1d5d0079a5cb’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/9e585f25f5988cb1f7e62c09a7fbf33ce0a526ae03cfb93292a35d8e2b427443’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/9f1aeac23927685ececfaf1b653b34d638db37d5b59dc09876dff9958481063c’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/a19cd352fa8207b38386b85b4047a3fb04c7a34528f9d3c340aca379280b538f’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/a3a4d858537faf87abde875319028b1138bac26d5a69e57fb0ea3b40b9aa7a2a’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/aa83cc4ec46773c1956f9c13e516577a82aaa87993ad816cc02a1dc85b81af89’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/ab68f524f9ac12f47ea3af71e0db2b80111fdda4fed7b8ef10e6e81d19ca5805’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/bff10f743391b8d007d4d5fcce424e2a36579d6e76e7060a96d7f1dd24e94d13’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/c991b5432313f0c926dd0ea68f89899f515bd90ad3d579f62815c97c35364511’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/d04e87dc6571f3cf2320effa090bd68007d5a56b65a0ff909aac19c0817c3dc1’: Read-only file system
Nov 17 16:08:00 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/d16e0cd0a20d87685eaa1d2f355850e9e2fe9fcd439cfd385e7420a330fa77da’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/d30076602e2e8b394055156a55a519af99f6309b12c7fa69df63c63cd403dd40’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/d82cbc087421e51431a510e394c5d783c2dc6af25361f77e9b3531cec493aed2’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/e090c080beee655b2bdd6946d44def85e7e7030a45f9d46a9002170f0e73fbf3’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/ebca6fdd5c258e474a390b1f228f1530e7ca1fad9e08c496773697c803b90144’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/eeac2130b812a686288113cb1d447a2641fe64942f1cd1dafdaafedaf05d8dfc’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/f87a0c38d1609f19f4cca1775de11f1e7ca41fedb54b9840a1f959d7cc56fb64’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/f9e26e50a99b7f1be25e6a8e0102eb29fa0fd345e6b427c2826775d2490c3fae’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/fc5ad4c50e60459ec41100e33ec374f9353a8278fc2cca72c72928bf8a33e98e’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/overlay2/l’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: preserving times for ‘/mnt/data/docker/overlay2’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/plugins’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/swarm’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/trust’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/volumes’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/tmp’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: cannot create directory ‘/mnt/data/docker/runtimes’: Read-only file system
Nov 17 16:08:00 umbrel external storage mounter[485]: cp: preserving times for ‘/mnt/data/docker’: Read-only file system
Nov 17 16:08:00 umbrel systemd[1]: Failed to start External Storage Mounter.
Nov 17 16:08:00 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 17 16:08:00 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
services.tor.ports contains an invalid type, it should be a number, or an object
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
Start over.
Fresh install from zero.
Delete the SSD partition or maybe you should change that SSD drive.
Do not format it in NTFS, only ext4 or just delete the partition, umbrel install will take care and create one in the process.
Thank you, I’m downloading fresh Umbrel 0.4.8 and will try to install it
Do you had funds in that node?
Here is a guide about restore funds
If you have funds in LN channels I would recommend the option 3. Easier and faster.
Nope. Just testing before to send something there. Looks like super unstable yet =(
After upgrade to 0.4.8 I have another error:
Error: Failed to connect external drive
There was an error connecting your external drive. Please consider using the recommended hardware listed on getumbrel.com
I hope I can’t killed my SSD by doing experiments with Umbrel
It’s weird because my linux laptop has seen no problems in SSD, successfully copying and reading data.
You know what we say… You are not a bitcoiner if you are not reckless :slight_smile:
