Failed to start containers help closing channels
Is a couple of days that my node with channels wasn’t working
i was out of home and it was impossible reach it via remote till today
i’ ve phisically rebooted, and via browser umbrel.local i have Error: Failed to start containers
i did a debug via ssh and flashed a new sd, unluckly the new sd i didn’t fixed the problem
i saw that sometimes is hard to fix this problem and my channels aren’t routing at all,
so for me is also ok just close the channels and make a brand new node
Thank you
Have you tried the following steps?
yes but i’ve got the same problem
if it can be useful for you this problem happened after a period of 1/2 days of line down
and this was the configuration:
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03115
Serial : 10000000d01db5c9
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=43.3’C
Throttling
throttled=0x0
Mem: 7.8G 110M 7.1G 8.0M 570M 7.6G
Swap: 4.1G 0B 4.1G
