Failed to connect external drive + How to access from local enthernet now Wi-Fi
Hello everyone!
I’ve been reading the similar threads and it did not work for me to format the SSD, restart the Umbrel, etc.
It’s my first time installing it and I don’t understand what the problem is here but I might have an idea.
The SSD it’s 2TB and everything works fine but the rack it’s from ORICO and the cable it’s only USB 2.0.
I tried both 2.0 and 3.0 port (even though the 3.0 it’s recommended) but can’t find a reason to not work just because of the USB and on laptop it connects automatically on each port.
Also, it seems that I can only connect to Umbrel if I’m on the Wi-Fi and not if I am connected directly by the enthernet cable. What settings should I apply from my router in this case?
