ubuntu 23.04
this is a new problem May 2023. here is some info:
I couldn’t fix it with those instructions (noob), so I installed Ubuntu 22 instead. Umbrel then installed correctly.
Did you install the 22 LTS Version ?
Someone can solved this issue ?
I have the same and unable to install Umbrel OS on my Ubuntu 23.04 ![]()
I can solve this issue. Steps:
- Instead of
curl -L https://umbrel.sh | bashto install, I didcurl -L https://umbrel.sh > install-umbrel.sh - Modify the
install-umbrel.shscript. Look at theinstall_docker_composefunction and change it to:
install_docker_compose() {
sudo apt-get install --yes libffi-dev pipx
sudo pipx install docker-compose
# we need to add /root.local/bin to the PATH
echo PATH="\$PATH:/root/.local/bin" | sudo tee -a /root/.bashrc > /dev/null
sudo source /root/.bashrc
- Save and run the script
bash install-umbrel.sh.
I hope this helps you.
Greetings
A workaround was published in the github issues: Debian12 install / pip install · Issue #1672 · getumbrel/umbrel · GitHub
