Recently received my Umbrel and started to set it up.
I needed to transfer a 425mb file to the Umbrel and was met with very low transfer rate. est time 1hr+
Stopped the transfer, switched to a wireless connection and rebooted. Tried again with the same result.
I also tried disabling Cloudfire DNS in settings, installing SAMBA, which did not work as well.
I could not establish a Samba connection in Windows Explorer at all.
My goal with this unit was to run HA and BTC node. Don’t think I’ll even try the BTC node at this point due to the block chain size.
Anyone have any suggestions on what could be causing this?
