i have 2.5Gb/s and umbrel use only this slow
Hey there! One thing worth checking: is the computer you’re using to upload files connected to Wi-Fi instead of ethernet? Because to reach 2.5Gbps, both your Umbrel Pro and the device you’re accessing it from need to be connected to your router via a wired (ethernet) connection.
@reDzik Try installing the MySpeed App from the Umbrel App Store and test your Internet speeds that way.
It is not a limitation of the umbrelOS … I have my Mini PC configured with bonded 2.5GB Ethernet Ports connected to my 5GB Fiber (up/down) Internet and can get the full bandwidth:
Just because you have 2.5GB Port, does not mean you will get full 2.5GB speeds without the right infrastructure to support it too.
Have you connected Umbrel using wifi before? you can try disabling the wifi in that case, to make sure it uses eth
wifi is off
transmission
idk what going on…
