umbrel@umbrel:~ $ ./umbrel/scripts/debug
0.5.1
Flashed OS version
v0.4.1
Raspberry Pi Model
Revision : c03114
Serial : 100000005bf50775
Firmware
Aug 3 2021 18:14:56
Copyright (c) 2012 Broadcom
version 40787ee5905644f639a2a0f6e00ae12e517a2211 (clean) (release) (start)
Temperature
temp=54.0'C
Throttling
throttled=0x0
Mem: 3.8G 99M 3.4G 8.0M 263M 3.6G
Swap: 0B 0B 0B
total: 2.6%
system: 2.6%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
tail: cannot open '/home/umbrel/umbrel/scripts/../logs/memory-monitor.log' for reading: No such file or directory
/dev/root 59G 3.2G 53G 6% /
Startup service logs
-- Logs begin at Tue 2022-08-16 18:53:17 UTC, end at Tue 2022-08-16 19:08:56 UTC. --
Aug 16 18:53:21 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Aug 16 18:53:21 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result 'dependency'.
External storage service logs
Aug 16 18:53:21 umbrel systemd[1]: Starting External Storage Mounter...
Aug 16 18:53:21 umbrel external storage mounter[504]: /status-server/set-status: line 31: /umbrel-status: Read-only file system
Aug 16 18:53:21 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Aug 16 18:53:21 umbrel systemd[1]: umbrel-external-storage.service: Failed with result 'exit-code'.
Aug 16 18:53:21 umbrel systemd[1]: Failed to start External Storage Mounter.
Aug 16 18:53:21 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Aug 16 18:53:21 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result 'dependency'.
Karen logs
tail: cannot open 'logs/karen.log' for reading: No such file or directory
Docker containers
Umbrel logs
ERROR: The Compose file './docker-compose.yml' is invalid because:
Tor logs
==== Result ====
