I am able to get Umbrel installed and can login to the web UI. My issue is that my external SSD connected via USB 3.0 is not a storage option. I am running Armbian Jammy on a Renegade board that is connected to a powered USB hub that my UGREEN SSD enclosure uses. Power should not be an issue and the drive is visible in Linux and has been partitioned and mounted. It is formatted in ext4. I can create directories on it in my testing via command line in armbian. The blue light is visible on the drive enclosure.
So, what else can I try to get the external drive to be an option in the web UI? I ran the debug log from the umbrel folder on the SD drive and did not get any automatically detected errors.
