Hi , I tried to revive an old thread to this a week ago, sadly without success. So I repost this as a new thread (hope that’s ok):
I noticed my note not reacting (snowflake log showed last traffic about two weeks ago). When I logged in, the Blockchain wasn’t syncing. I ran the suggested updates and restarted, after that, I got this error message. The node ran fine until then. When I logged in, the only thing was that it told me it was running hot currently.
I made a debugging log per the guide, which can be found here.
I successfully recovered the channel backup and the backup ID via SSH but I am lost on how to idetify the cause of the error and how to fix it. Any help would be greatly appreciated!
Hi, sadly I still don’t know if my node can be saved. Enclosed you find a selection from the lof I posted in the original message. Various start-up processes fail, but I do not know what I can do about it. Help would be greatly apprciated!
Jun 18 18:52:03 umbrel umbrel startup[19275]: ERROR: for manager Cannot start service manager: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/a3d38f7607129100c758ab445e615437886dee15f2adaf5a47f5b6be6f11b40d: no space left on device: unknown
Jun 18 18:52:03 umbrel umbrel startup[19275]: Starting tor_server ... error
Jun 18 18:52:04 umbrel umbrel startup[19275]: ERROR: for tor_server Cannot start service tor_server: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/00c759772eaa7d57e0ecd11678aeeb468092d0b24b5add832d2d61ddda4782d6: no space left on device: unknown
Jun 18 18:52:04 umbrel umbrel startup[19275]: Starting dashboard ... error
Jun 18 18:52:04 umbrel umbrel startup[19275]: ERROR: for dashboard Cannot start service dashboard: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/4965fc749a17fba5861a97aedfb0017dd82da584be38cc9f225fff825f35fc17: no space left on device: unknown
Jun 18 18:52:04 umbrel umbrel startup[19275]: Starting auth ... error
Jun 18 18:52:04 umbrel umbrel startup[19275]: ERROR: for auth Cannot start service auth: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/3868e04c595ed7132afac5682ae8d56e9c7b5ff736cf54d2272e399c41775e30: no space left on device: unknown
Jun 18 18:52:04 umbrel umbrel startup[19275]: Starting tor_proxy ... error
Jun 18 18:52:04 umbrel umbrel startup[19275]: ERROR: for tor_proxy Cannot start service tor_proxy: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/294578eb81b52949fcadb145b41093703c729195abdde9c459a0a97b05a391ff: no space left on device: unknown
Jun 18 18:52:04 umbrel umbrel startup[19275]: ERROR: for manager Cannot start service manager: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/a3d38f7607129100c758ab445e615437886dee15f2adaf5a47f5b6be6f11b40d: no space left on device: unknown
Jun 18 18:52:04 umbrel umbrel startup[19275]: Encountered errors while bringing up the project.
Just setting up my raspberry pi and node for the first time, having the same “system service failure”, I’ve tried reflashing the SD, and obviously restarting the machine. Short of buying new cords, and hardware, what else can I do? Its all official parts, it came in a kit, i’m using a SanDisk 2TB pro SSD. I’m new to this, so forgive me if i overlooked something obvious, but can anybody help?
