Hi all,
My trouble started with a failing MicroSD card. Reflashed and then got message Failed to Connect to External Drive. I have not been able to remedy the situation with the troubleshooting guides. Here is debug info. Thank you for any help you can offer!
0.5.3
Flashed OS version
v0.5.3
Raspberry Pi Model
Revision : c03115
Serial : 10000000737bc8b8
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=28.2’C
Throttling
throttled=0x0
Mem: 3.8G 117M 3.5G 8.0M 202M 3.6G
Swap: 0B 0B 0B
total: 3.1%
system: 3.1%
bitcoin: 0%
Memory monitor logs
2024-01-08 02:16:09 Memory monitor running!
/dev/root 15G 3.6G 9.9G 27% /
Startup service logs
– Logs begin at Mon 2024-01-08 02:30:52 UTC, end at Mon 2024-01-08 02:53:55 UTC. –
Jan 08 02:30:57 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Jan 08 02:30:57 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Jan 08 02:30:57 umbrel systemd[1]: Starting External Storage Mounter…
Jan 08 02:30:57 umbrel external storage mounter[493]: Running external storage mount script…
Jan 08 02:30:57 umbrel external storage mounter[493]: Found device “JMicron Generic”
Jan 08 02:30:57 umbrel external storage mounter[493]: Blacklisting USB device IDs against UAS driver…
Jan 08 02:30:57 umbrel external storage mounter[493]: Checking USB devices are back…
Jan 08 02:30:57 umbrel external storage mounter[493]: Checking if the device is ext4…
Jan 08 02:30:57 umbrel external storage mounter[493]: No, it’s not ext4
Jan 08 02:30:57 umbrel external storage mounter[493]: Formatting device…
Jan 08 02:30:57 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Jan 08 02:30:57 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Jan 08 02:30:57 umbrel systemd[1]: Failed to start External Storage Mounter.
Jan 08 02:30:57 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Jan 08 02:30:57 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
karen is getting triggered!
Killing background services
Stopping installed apps…
Stopping app bitcoin…
Stopping bitcoin_i2pd_daemon_1 …
Stopping bitcoin_server_1 …
Stopping bitcoin_app_proxy_1 …
Stopping bitcoin_tor_1 …
Stopping bitcoin_bitcoind_1 …
Stopping bitcoin_tor_1 … done
Stopping bitcoin_app_proxy_1 … done
Stopping bitcoin_server_1 … done
Stopping bitcoin_i2pd_daemon_1 … done
Stopping bitcoin_bitcoind_1 … done
Removing bitcoin_i2pd_daemon_1 …
Removing bitcoin_server_1 …
Removing bitcoin_app_proxy_1 …
Removing bitcoin_tor_1 …
Removing bitcoin_bitcoind_1 …
Removing bitcoin_app_proxy_1 … done
Removing bitcoin_i2pd_daemon_1 … done
Removing bitcoin_tor_1 … done
Removing bitcoin_bitcoind_1 … done
Removing bitcoin_server_1 … done
Going to remove bitcoin_i2pd_daemon_1, bitcoin_server_1, bitcoin_app_proxy_1, bitcoin_tor_1, bitcoin_bitcoind_1
Stopping Docker services…
Stopping nginx …
Stopping dashboard …
Stopping auth …
Stopping manager …
Stopping tor_proxy …
Stopping tor_proxy … done
Stopping nginx … done
Stopping auth … done
Stopping dashboard … done
Stopping manager … done
Removing nginx …
Removing dashboard …
Removing auth …
Removing manager …
Removing tor_proxy …
Removing auth … done
Removing dashboard … done
Removing nginx … done
Removing manager … done
Removing tor_proxy … done
Docker containers
NAMES STATUS
Umbrel logs
Attaching to
Tor Proxy logs
Attaching to
App logs
bitcoin
Attaching to
==== Result ====
