"Error: System service failed" after power failure
After a sudden power failure last night, my umbrel does not start anymore and states the above message in the browser. The start script says the following – is anyone able to help, please?
============= STARTING ===============
============== UMBREL ================
Setting environment variables…
Starting karen…
Starting status monitors…
Starting memory monitor…
Starting backup monitor…
Starting decoy backup trigger…
Starting umbreld…
Starting Docker services…
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 802, in urlopen
**response_kw,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 504, in _make_request
enforce_content_length=enforce_content_length,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connection.py”, line 388, in request
self.endheaders()
File “/usr/lib/python3.7/http/client.py”, line 1259, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1034, in _send_output
self.send(msg)
File “/usr/lib/python3.7/http/client.py”, line 974, in send
self.connect()
File “/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py”, line 27, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.7/dist-packages/requests/adapters.py”, line 497, in send
chunked=chunked,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 845, in urlopen
method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.7/dist-packages/urllib3/util/retry.py”, line 470, in increment
raise reraise(type(error), error, _stacktrace)
File “/usr/local/lib/python3.7/dist-packages/urllib3/util/util.py”, line 38, in reraise
raise value.with_traceback(tb)
**response_kw,
self.endheaders()
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 602, in get
return self.request(“GET”, url, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/adapters.py”, line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/bin/docker-compose”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 70, in project_from_options
enabled_profiles=get_profiles_from_options(options, environment)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 153, in get_project
verbose=verbose, version=api_version, context=context, environment=environment
File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 43, in get_client
environment=environment, tls_version=get_tls_version(environment)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 222, in _retrieve_server_version
f’Error while fetching server API version: {e}’
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Failed to start containers
After flashing another mSD with a clean umbrel, the error persists (though now it says " Error: Failed to start containers").
Handy guide here might help. Let me know how it goes!
