Error response from daemon: No such container: "tailscale"
I’d like to view the logs that my apps (Lightning Node, RTL, ThunderHub, etc.) are generating.
SSH’ing into my Umbrel, it seems like this would be where I might find the logs:
~umbrel/logs
When I
cat umbrel/logs/status-monitor.log
I get a flood of
Error response from daemon: Container b82573801767b16284c2bf6386fe7c6aebb910c15558a19f9825576e0a75e43b is restarting, wait until the container is running
Error response from daemon: No such container: “tailscale”,
I have uninstalled tailscale from Umbrel via the GUI, and through the CLI.
So, my questions are
  1. Am I looking in the right place to view logs for my apps (Lightning Node, RTL, ThunderHub, etc.)?
  2. Has anyone else seen (and successfully stopped) the loop that I’m seeing in status-monitor.log?
if you had a outage or something the didnt let an install of uninstall complete you may have docker containers that need pruned.
ssh in and see if something is in a loop
docker container ls -a
You can also follow the app logs from the docker container id
for example
-replies-
9b123ca65bd1 getumbrel/bitcoind:v24.0.1…
running
docker logs --follow --tail 200 9b123ca65bd1
would start following bitcoin logs and spit out the previous 200 entries
where as
docker logs --tail 200 9b123ca65bd1
would just give the last 200 entries but not follow.
hope this made sense and helps somehow.
if you have a container that needs pruned to stop the loop you can do that too
No luck with the error, but this method helped me do what I really wanted, which was look at each app’s logs. Thanks!
do you see some app in a start loop?
I do not see any sign that something is stuck in a start loop after
Is there another method I might use to check?
