Hey guys, I have been working for more than 1 week now to get my node operational again. Until yesterday, I had managed to get my bitcoin node operational. After that, it was not possible to get the Lightning node app installed. After performing a retstart / reboot, I only log in via SSH. Something doesn’t seem to be right with the docker. In the meantime I have carried out a number of assignments which I came across in the community as a solution. However, I am not getting any further. Can any of you see where it’s wrong and how to fix it?
Memory monitor logs
/dev/root 29G 29G 0 100% /
Startup service logs
– Logs begin at Mon 2023-05-08 09:17:01 UTC, end at Mon 2023-05-08 12:57:59 UTC. –
May 08 09:17:06 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
May 08 09:17:06 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
May 08 09:17:06 umbrel systemd[1]: Starting External Storage Mounter…
May 08 09:17:06 umbrel external storage mounter[491]: /status-server/set-status: line 31: echo: write error: No space left on device
May 08 09:17:06 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
May 08 09:17:06 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
May 08 09:17:06 umbrel systemd[1]: Failed to start External Storage Mounter.
May 08 09:17:06 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
May 08 09:17:06 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
Umbrel logs
Tor Proxy logs
==== Result ====
Last login: Mon May 8 12:56:25 2023 from 2a02:a462:55b7:1:a4dd:7c18:ea34:ad12
umbrel@umbrel:~ $ ~/umbrel/scripts/stop && sudo reboot
Umbrel must be stopped as root
Please re-run this script as
sudo ./scripts/stop
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/stop && sudo reboot
[sudo] password for umbrel:
Sorry, try again.
Killing background services
Stopping installed apps…
Stopping Docker services…
WARNING: The TOR_PROXY_PORT variable is not set. Defaulting to a blank string.
WARNING: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
WARNING: The NGINX_PORT variable is not set. Defaulting to a blank string.
WARNING: The NGINX_IP variable is not set. Defaulting to a blank string.
WARNING: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
WARNING: The UMBREL_AUTH_SECRET variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
WARNING: The MANAGER_IP variable is not set. Defaulting to a blank string.
WARNING: The AUTH_PORT variable is not set. Defaulting to a blank string.
WARNING: The AUTH_IP variable is not set. Defaulting to a blank string.
WARNING: The NETWORK_IP variable is not set. Defaulting to a blank string.
sudo ./scripts/stop
Sorry, try again.
