Anyone else having issues with Tailscale on 0.5.1? After the update restarted my Umbrel it was stuck on starting, I removed it and attempted a reinstall but never get past installing.
I’m running in a Proxmox container and gave up trying to get it to work with the GUI. I installed it directly to the container after following these instructions from Tailscale - https://tailscale.com/kb/1130/lxc-unprivileged/
Yes, same result here. I’m running on Ubuntu on PC, what’s your setup?
Unfortunately I doubt this is super helpful, but I was also having issues with Tailscale not starting after upgrading from 5.0 to 5.1. A clean reinstall fixed the problem and it all seems to be working. Of course that’s less than ideal, only did a reinstall to change external hard drives
