I get this error when I try to create the usb install disk. It happens at 98.3% finished. Is this an error in the code?
.iso Image Extraction Failure
Extracting: E:\usr\lib\systemd\system\systemd-tmpfiles-clean.timer (539 bytes)
Extracting: E:\usr\lib\systemd\system\system-update-pre.target (551 bytes)
Extracting: E:\usr\lib\systemd\system\system-update.target (625 bytes)
Extracting: E:\usr\lib\systemd\system\system-systemd\x2dcryptsetup.slice (454 bytes)
Unable to create file: [0x00000003] The system cannot find the path specified.
Extracting: E:\EFI\BOOT\BOOTX64.EFI (from ‘/efi.img’, 156 KB)
Found USB 3.0 device ‘USB DISK 3.0 USB Device’ (13FE:6700)
1 device found
Disk type: Removable, Disk size: 16 GB, Sector size: 512 bytes
Cylinders: 1887, Tracks per cylinder: 255, Sectors per track: 63
Partition type: MBR, NB Partitions: 1
Disk ID: 0x00000000
Drive has a Zeroed Master Boot Record
Partition 1:
Type: FAT32 LBA (0x0c)
Detected File System: FAT32
Size: 14.5 GB (15524167680 bytes)
Start Sector: 2048, Boot: Yes
